Old 11-29-2007, 05:35 PM
northern piper's Avatar
northern piper northern piper is offline
po705 help needed badly!
3 days ago I had to replace the starter on my 2000 windstar. Everything went fine. On restarting 1 day later I had a blinking od light and found out that my alternator wasn't charging the battery. I've just replaced the alternator and the battery is charging fine I think. I've got a po705 code now. Is this a sensor switch ...??
Please offer advice!
Piper
Old 11-29-2007, 06:35 PM
CnlK CnlK is offline
Re: po705 help needed badly!
P0705 Is: Transmission Range Sensor Circuit Malfunction. The Transmission
Range selector switch is accessible on top of the Tranny if you remove
the Air filter / MAF sensor assembly. A flashing OD light indicates that
a transmission malfunction was detected. You mentioned recently changing
the alternator. My windstar acted very strangely on low battery voltage
when the alternator failed. Try clearing the codes first and and see if they
return. I have not personally changed the Tranny range selector switch, but
there are several posts on this topic that have troubleshooting and replacement
information.
Old 11-29-2007, 07:07 PM
wiswind wiswind is offline
You may also want to verify that your battery is good.
If it is the original......at 7+years.....you are pushing it.
The reason that I bring this up.....a weak battery will place a extra load on the alternator.....and, if serious enough, can cause your new alternator to fail.
Also, make sure that the battery terminal connections are clean and tight, as well as the connections at the starter (which gets a lot of salt spray down there).
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-30-2007, 02:51 PM
ok so I've replaced the battery and alternator. The van starts really well. When in park in starting the od light flashes, once you drive away it goes off within about 100 yards. So, I'm thinking it's the transmission position switch (neutral safety switch). I've ordered one but am wondering about proper alignment. Anyone replaced one of these on a 2000 windstar 3.8??
I'm doing this tomorrow (Sat) morning. Any points, ideas, tech tips really appreciated!
Piper
Old 09-30-2010, 12:31 AM
Ed_Strong's Avatar
Ed_Strong Ed_Strong is offline
Son of a Mechanic
I'm sorry for resurrecting a very old thread!!!
But I'm having a very similar situation with my 2000 Windstar
It's intermittently flashing the O/D light and I got codes:
P0702 Trans Range Snsr CKT fault
P1702 TRS CKT Intermittent fault
So I would like to know how did it worked for you Northern Piper? Did the TRS Sensor, Transmission Position Switch (Neutral Safety Switch) fix your problem? How easy was it to replace?
Current Rides:
2018 Honda Pilot EX-L - 3.5L V6 -{|}- 2004 Toyota Matrix XR 4WD 1.8 I4
________________________________________
Past Rides:
2000 Ford Windstar LX - 3.8L V6 SFI - {|} - 2003 Ford Expedition XLT - 4.6L V8 SFI
2005 Chevrolet Malibu LS - 3.5L V6 SFI - {|} - 1991 Chevrolet Corsica LT - 3.1L V6 MFI
1995 Dodge Grand Caravan SE - 3.3L V6 MFI - {|} - 1980 Ford Mustang - 3.3L L6 1BBL
Old 09-30-2010, 07:21 AM
Hi Ed
yes, replacing the trs solved the problem. It wasn't a difficult job to do, a bit tough on the back leaning in. With the air filter housing etc out of the way it was ok. I didn't take the cowl off. The only thing I'll say is that the trs is a bugger to get off. The plastic within the switch was completely attached to the metal post that it moves within the trans. I had to completely break the trs in order to remove it. Once off, I shined up the post with some emery cloth, added a little bit of lube and slid the new trs on. The other thing I found was that it seemed impossible to remove the shifter cables individually but instead I just detached them as a unit. On the new trs I bought, it had an alignment mark so no special tool was needed.
Other than that, it was a pretty easy job.
p
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 09-30-2010, 11:46 PM
Ed_Strong's Avatar
Son of a Mechanic
Thanks for the reply Northern Piper...
I already picked up the replacement TRS and plan on put in it on as soon as the sun starts shinning again!
Current Rides:
Past Rides:
Old 10-01-2010, 10:23 PM
Ed_Strong's Avatar
Son of a Mechanic
Well got it installed today... took about an hour and a half just because the switch was hard to remove and space is so limited. I had to break it aswell in order to be able to take it out. I had the perfect sized pry bar
I took the van to work to test (20 mins mixed driving each way) and everything seems to be in order now. So thanks for the help Northern Piper
Current Rides:
Past Rides:
Old 12-31-2010, 05:56 PM
glad to know it worked!
2000 windstar 3.8
Muskoka Canada
