Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-29-2007, 04:08 PM
FL 3.2L FL 3.2L is offline
Check out the inside of this 4L-30E
http://forums.bimmerforums.com/forum...d.php?t=839875
No need to change that fluid, eh?
'97 Rodeo LS 4X2 Dueler Alenzas 4L-30E 200K
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 11-29-2007, 04:24 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Check out the inside of this 4L-30E
can you pull the photos and host and then post them hear? I went to view the images and they say I need a username and password.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 11-29-2007, 04:27 PM
Let me try. Sorry about that...
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 11-29-2007, 04:34 PM
Isuzu Guy
"The page isn't redirecting properly"
-Ryan
Isuzu Moderator
Car Show Tips
Old 11-29-2007, 05:09 PM
I give up...! I tried using [img] tags without success.
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-03-2007, 10:28 PM
Finally...
The main pan
The magnet
The overdrive pan
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-04-2007, 12:22 AM
Andie_J Andie_J is offline
This the fill pans of an automatic transmission? Andie
O4 Rodeo, 3.2, Auto, OME's 912's, Kangaroo Chaser
05 Saab, (My two BABIES)
Assorited Pickups for the ranch
Old 12-04-2007, 06:43 PM
Yeah - from a BMW. The main pan design is better for the BMW. Looks like it holds more fluid and the fill plug is on the side of the pan, rather than on the bottom. I wonder why the Isuzu version is different. Clearance? Exhaust or 4wd components in the way?
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-04-2007, 10:49 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
I fail to see a problem with that. Good for another 100k miles.
LOL.
Dang, almost said it with a straight face.
--Dave
1999 Rodeo LS 3.2 4x4 5 Speed
32x11.50-15 BFG T/A KO
3" Lift - Rancho 9000x
Rear No-Slip Locker
Flowmaster 2.25" 50 Series
There is a very fine line between "hobby" and "mental illness." - Dave Barry
Old 12-05-2007, 04:58 AM
Tom01Rodeo Tom01Rodeo is offline
I've been changing my fluid regularly, but after that photo I think I'll pull the overdrive pan sometime soon.
Old 12-05-2007, 06:11 AM
That last pic looks like my last attempt at choc. chip cookies!! I feel lucky that i dont have to worry bout 2 pans, since mine only has one big one. Andie
Old 12-05-2007, 07:32 AM
I didn't find the bottom of my overdrive pan to have a ton of paste when I dropped it. I only did it once in the vehicle's life, but I swap some fluid often. I'll guess yours isn't that bad!
'96 Jetta 249K
'97 TJ 156K
'02 VW Cabrio 70K
'03 E46 107K
Old 12-05-2007, 09:45 AM
Kentoxboy Kentoxboy is offline
I took out the overdrive pan by accident because I thought the gasket was leaking, turn out that it was the accumulator piston. But when I look at the OD pan, it wasn't that bad... as long as you change your tranny fluid frequently.
