Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 11-29-2007, 01:45 PM
Michelg777 Michelg777 is offline
Slow Warm Up, Low Heat
I have a 2001 Montana 3.4L with 66K miles. I believe my thermostat is stuck open. It takes about 20 minutes to break 170 on the temp gauge. I am not sure where the thermostat is located. I followed the upper radiator hose to an area behind the exhaust manifold outlet just below the throttle body. Is this the correct location. What has to be removed in order to access it. What kind of job am I looking at
Old 11-29-2007, 06:07 PM
brian 1 brian 1 is offline
Re: Slow Warm Up, Low Heat
it is the correct location.the easy way is to remove the throttle body,2 13mm bolts,disconnect the by-pass tube that is above the water pump.after you remove you will see the t-stat housing.remove the upper bolt.also 13mm.the lower bolt is a little trickey.use 13mm wrench and loosin the bolt,but do not take it out.you will have just enought room to get the housing out.I do alot of the t-stats on these at the dealer.its better than removing the rear exh pipe.
Old 12-02-2007, 07:36 AM
LMP's Avatar
LMP LMP is offline
MIchel when you do it, it would be interesting you can take a few photos to complement these very precise Brian's instructions because it could help several others in the future as this subject comes quite often on several AFforums in the same family of cars. ALso make sure you report the conclusion as to whether it solved your problem or not.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 12-02-2007, 10:21 AM
Thumbs up Re: Slow Warm Up, Low Heat
Thank you Brian for the excellent instructions. The whole job took me 3 hours. It was a piece of cake after removing the throttle body. I read the request for pictures after the job was done. I will take a pic of how to remove the heater bypass tube, polution control tube and then the throttle body. After removing the three components, thermostat removal and replacement was easy. Thanks again for your help!
Old 12-02-2007, 10:45 AM
rkvons's Avatar
rkvons rkvons is offline
Thank you Brian for the excellent instructions. The whole job took me 3 hours. It was a piece of cake ...
You still owe us a "Did it fix your problem?" answer.
Old 12-02-2007, 01:58 PM
northwoods60 northwoods60 is offline
same problem here, in Ontario, Canada. The OEM intake gasket is a lot to blame. Plus changing the thermostat. NOW it heats up great but the gas mileage is very poor. Time to go back to mechanic to find out why.
OEM intake gasket, check the phil edmonston website.
Old 12-02-2007, 04:14 PM
To All: Changing the therostat did fix my problem. It warms up to the proper temp in a short period of time. The dash gauge reads about 190. I have a comment for the person that mentioned they are getting poor gas milage after changing the therostat. When I was putting the throttle body back on I nicked the gasket pretty good. I continued with job without cleaning up the gasket. When I fired the engine up it wasn't running right. I took the throttle body back off and cleaned up the gasket. Its running correctly now.
I took some pictures. Next project is figuring out how to post them.
Mike G.
Old 12-02-2007, 06:25 PM
1999montana's Avatar
1999montana 1999montana is offline
Smile Re: Slow Warm Up, Low Heat
...I took some pictures. Next project is figuring out how to post them....Mike G.
If the pics are .jpegs you can post them on PhotoBucket.com (set up a userID, upload the pics) and then reference the link PhotoBucket.com creates.
Old 12-02-2007, 06:53 PM
Thumbs down Re: Slow Warm Up, Low Heat
I am going to approach the mechanics who did the job. At $1.00 a quart here in Ontario, Canada, plus with our cold weather (yes, we have winter here now), I hope to get this problem resolved soon.
Old 12-04-2007, 12:28 AM
JabbaTHutt JabbaTHutt is offline
I was about to ask what kind of temps people where running at in ontario, mine is running about 60-65, me thinks this is a little low.
As for milage, well the computer says we average about 17-20mpg. Is this normal or bad? Ya its like $1.04 a litre here.
2003 Montana EXT
Most options
Niagara Falls
Canada
Old 12-04-2007, 12:56 AM
GregA's Avatar
GregA GregA is offline
...I took some pictures. Next project is figuring out how to post them. Mike G.
Hi Mike,
I would also be interested in the exact "step-by-step" procedure you used. If you could post that, I would be grateful, because I have the same issue on my van.
P.S. I sent you a private message.
Take Care,
Greg A.
2001 Chevy Venture w/some "enhancements" ~ 105K Miles (Dec. 2010)
1992 Jeep Cherokee Laredo, 4.0L, Automatic ~ 155K Miles (Dec 2010)
Old 12-05-2007, 09:10 AM
LMP's Avatar
LMP LMP is offline
IF you have any problem doing this in a short time, just e-mail them to
[email protected]
and I'll host them and make them available immediately ..which does not stop you from posting them at photobucket when you have time to.
Old 12-07-2007, 05:44 PM
OK... I figured out how to post on Photo Bucket.
Here are the pictures.
brian 1 posted the procedure.
Note: remember to follow the upper radiator hose, it will lead you to the thermostat housing.
http://i267.photobucket.com/albums/i...Montana34L.jpg
http://i267.photobucket.com/albums/i...tlebody34L.jpg
http://i267.photobucket.com/albums/i...tBypass34L.jpg
Old 12-07-2007, 10:12 PM
Where in there is the thermostat?
Thanks
2003 Montana EXT
Most options
Niagara Falls
Canada
Old 12-09-2007, 07:18 PM
its was the thermostat plus the OEM gasket that needed to be change. The vacuum hose needed to be re-installed, very poor gas mileage. Plus the cold weather also seems to be sucking the hell out of the gas mileage. There is plenty of get up and go in the old van.
I have a Air Hog Filter (FRAM) installed, but I really do not feel there is much difference in performance as opposed to having the OEM air filter. Costmetically pretty, and great marketing, but actual use..nothing.
