Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 11-29-2007, 09:50 AM
back2life's Avatar
back2life back2life is offline
cooling fans are rigged!
fuses are good looks like someone wired srt8 power from fusebox to white looking boxes on fans and grounded to boby. i disconnected and watched scanner till about 214 deg and computer shows signal for fans to run but they dont. i need help with what to look for to diagnose the problem. would the temp switch keep the fans from running even tho there is a signal coming from computer?
Old 11-29-2007, 06:45 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: cooling fans are rigged!
Yes if the temp sensor is bad or has a short then they wont run.
BUT, since its been jerry rigged its hard to say what wong.
Sounds like you'll need to do some wire tracing, fun.
1999 Grand Am SS 3.4 OHV
Old 11-29-2007, 07:52 PM
back2life's Avatar
i will be disconnecting to try to trace the wiring. where is the switch located and is there more than one? what do i do about the relay and what are the little white boxes conected to the fans?
