I have the old tried and true 3.8L Series II V6.
This past Monday the pulley on the tensioner (for the accessory system) seized up. I have a replacement pulley, but my question is - how do I get the old pulley off. The tensioner has a 15mm nut that is used to rotate the tensioner to install or remove the serpentine belt. If I turn that nut with enough force, will it come off so I may remove the pulley? Thanks in advance for any advice! |
Re: Tensioner Pulley Remove/Install
That bolt is reversed thread, so make sure you turn it clockwise to loosen, or you'll snap it off overtightening it trying to remove it. But yes, the bolt in the center is what you remove to change that pulley.
![]() Still waiting for the "good old days" I'll get to bore my future grandchildren with! |
richtazz ![]()
I took richtazz's advice and it worked out great last night. New pulley is installed and car is back on the road.
Thanks again! |
