Old 11-29-2007, 05:37 AM
seandr seandr is offline
Power Steering
How Do I Flush My Power Steering?
Old 11-29-2007, 08:28 PM
wiswind wiswind is offline
Re: Power Steering
You need to use Mercon ATF, not power steering fluid for your 2000 windstar.
Mercon V should be fine.
Mobil 1 ATF is a good product that is easy to find.
You can use a turkey baster.....and suck fluid out of the power steering fluid resevoir and add fresh....Run the motor, turning the steering wheel from limit to limit (but not resting against the limit), then suck the fluid out of the resevoir, and repeat this process about 5 or 6 times.
OR, you can remove the return line to the resevoir, and plug the spot on the resevior to prevent it from draining out, if you have a remote resevoir (not mounted to the side of the power steering pump), then several members have mentioned a screen in there that can become clogged with junk.....so check and clean it as needed...
Direct the return line into a container.
Have a helper give the starter a touch....but don't let the motor run......the resevoir will drain REAL fast....and you don't want to drain it all the way......to prevent air from getting on into the power steering system.
Add fresh fluid.......touch the starter again......add fresh fluid......and do this until you run about 2 or 3 quarts of new ATF through.
Reconnect the return line to the resevoir, and fill resevoir to the full line (but don't overfill).
If the return line is not long enough to direct into a container....you can buy a clear hose......just big enough to slide over the return line.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 12-02-2007, 10:36 AM
rodeo02 rodeo02 is offline
Re: Power Steering
Originally Posted by wiswind
..Have a helper give the starter a touch....but don't let the motor run......the resevoir will drain REAL fast...
Hehee.. No doubt about that wiswind. I think I've still got oil stains from head to toe in my garage to prove that point!
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 12-02-2007, 10:40 PM
tripletdaddy tripletdaddy is offline
Re: Power Steering
May I suggest two alternate methods of turning the ps pump for this procedure that would also eliminate the need for a second person and insure you won't accidentally get too much out at one time. If you do choose to use the starter to turn the pump, disconnect the ignition system so it won't fire and fluid get away form you. But, the one person method would be to loosen the belt off the ps pump and manually rotate it. You will be able to better control the rate the fluid leaves the reservoir and you can refill it as needed before it runs out and gets air in, and less likely to have fluid all over from a hose gone wild. I haven't tried it yet, but I hope to soon.
Old 02-14-2008, 10:35 PM
mundy5 mundy5 is offline
Re: Power Steering
My power steering is whining after about 30 + minutes of running. So it's time for a flush. I can see that Mobil 1 ATF is an easy solution. My question to you tripletdaddy is how do you go about doing your one man solution.
I can see that you need to loosen the belt and I assume that the belt will require a belt puller or something from an autoparts store. But what else needs to be done?
I have a 2003 and I have never replaced the p/s fluid before but desperately need to do it b/4 my wife takes a long trip this summer.
if I could get some photos, that would be really helpful. I noticed that the chiltons and haynes all use old photos from back in '98 or so and it's not always what is under my hood.
thanks,
mundy5
Old 02-15-2008, 02:06 AM
Re: Power Steering
If you haven't, you should read this thread - "2000 power steering fluid change"
http://www.automotiveforums.com/vbul...oto=nextnewest
There were two posts that explained reasonable approaches to the fluid change, though I like the idea of disabling the engine from running. He said he disconnected the fuel pump relay. I had suggested to disconnect the wire connector to the ignition coil. I don't know that one method is any worse than the other. For me, I'd crank the engine for a few seconds if that and then check/top off the reservoir with new fluid to start. Letting the engine run to pump out the fluid sounds too dicey to me as it could go too quick and you could get air into your system, which is better to avoid since you can. One guy said he got fluid everywhere when he ran the engine, something else worth avoiding.
These two methods avoid disconnecting the serpentine belt. That involves using a 1/2" breaker bar or long pry bar to turn the tensionerr to release and remove the belt. Now you can by hand rotate the steering pump pulley. I would probably find something I could engage with the pulley in one of its holes like a handle to turn it faster. With this method you can watch the fluid level go down while it pumps and stop and add new fluid as necessary avoiding accidently getting air in the system. The fluid discharge will also be very low and less likely to blast out all over.
Down sides to this method:
This is all theoretical that it will work
Slow
Does not include turning of steering wheel side to side to
exchange all old fluid in rack.
Removal of belt is harder than the two methods that avoid
using running engine
Old 02-15-2008, 03:49 PM
MARZBX157's Avatar
MARZBX157 MARZBX157 is offline
Re: Power Steering
A few items which proved useful for me were 3/8"brass fitting, 3/8" vacum cap, and of course, the 3/8" clear tubing to minimize any mess. The fitting will keep the hoses from coming apart and the cap plugs the resevoir before any oil spills. Remove the fuel pump relay and your ready to do the flush.
2000 Windstar 3.8 V6
Old 02-16-2008, 09:44 AM
road_rascal's Avatar
road_rascal road_rascal is offline
Send a message via Yahoo to road_rascal
Re: Power Steering
I'd like to know how the belt tensioners are set up on everyone else's van. There's no way I can get a 1/2" breaker bar onto the tensioner. On mine, I have to lift the van and from underneath use a 13mm box wrench to rotate the tensioner counterclockwise and use the little 'clip' to hold the tensioner in place to remove the belt. It's easy, but I can't do this from the top.
*Twin Cities MN*
Old 02-16-2008, 11:37 AM
northern piper's Avatar
northern piper northern piper is offline
Re: Power Steering
I don't know about you guys but the 3 times I've removed and replaced my serpentine belt (2 broken/abused belts, 1 alternator install) I've simply pulled on the belt at the top and slipped the belt off the smooth pulley by the alternator. I don't use any sort of tool, just a gentle pull (while maybe a bit more grunt than "gentle") and the belt comes off. I agree it's a tight fit in there, possibly a serpentine belt tool would work but I've never needed one.
Piper
2000 windstar 3.8
2010 honda pilot touring
Muskoka Canada
Old 02-17-2008, 03:03 AM
Re: Power Steering
On my 95, 3.8L, the hole for the 1/2" breaker bar is inaccessible. The tensioer is way in the back under the cowl and tight against the fender wall. I have tried turning the tensioner with a wrench on the pulley bolt, but the best method I have found by and far is a long mechanics pry bar that I put in behind the tensioner arm and is jammed between the end of the arm and the main body of the tensioner. Mine doesn't have a "clip" to hold it retracted, wished it did. I have tried pulling on the belt like Piper, but I must not be as hulking. The 3.0 engine appears to have a more accessible tensioner, that looks like the 1/2" socket hole can be used.
Old 04-10-2008, 11:03 AM
jcasaccio jcasaccio is offline
Re: Power Steering
Just empty the resovior once a month and replace with fresh fluid. You won't need to flush then. This has worked well for me for 17 yrs.
JC
Old 04-10-2008, 12:29 PM
tartersauce tartersauce is offline
Re: Power Steering
JC
Use a Turkey sucker, or a hand pump both cheap. Suck out res, and refill.
Run a bit, and repeat. This takes time, but it also gets all the crap out of the pump and lines which would be left if you drained the lines anyway.
It just takes time and I also do this on my own rides. Simple and works just as good..
Old 04-10-2008, 01:16 PM
12Ounce 12Ounce is offline
Re: Power Steering
Northern Piper, I also just hand-pull, with gloves, the belt for removal. But I'm not sure this is so easy to do on '98 and earlier models. The serpertine belt got a redesign in '99.
As for ps fluid; when I remember to ... I just empty and refill the reservoir with each engine oil change. Still using the original pump at 230kmi ... but it does now need changing ... if I can ever get around to it!
Old 04-11-2008, 03:56 PM
Andrew1941 Andrew1941 is offline
Re: Power Steering
2001 Deathstar - went and got a 3/8" brass hose connector, vaccum plug set, some clear 3/8" ID hose and Mobil 1 AFT Synthetic.
FISRT and FOREMOST - Stick a rag under the PS reservoir to catch any spills. Pull the return hose off (top hose connection) the reservoir (twist it a bit to loosen) and be ready to cover the reservoir hole with your finger after getting the hose off. Then slip the plug over the reservoir connection (I only spilled a couple of drops). Then insert the hose connector in the PS return hose and connect the clear hose to that too. Take the clear hose to a 1 gallon pail and SECURE the hose to the bucket so it doesn't get away from the bucket when the PS fluid is being pumped. Pull the fuse from the fuel pump (look in your van manual to see which one) so the van won't start. If there is PS fluid in the reservoir to the fill line, then try starting the van, if not top it off first. It won't likely start, but possibly the first try as you clear out the fuel. Turn van off fast and go see what volume your PS pump moved. I was able to try turing the engine over two or three times for a few seconds each time before draining the PS reservoir. After draining it down, I checked out the screen with a flashlight. I then took some cue-tips and cleaned the small amount of debris off the screen. Be careful not to push it down through the screen. Then fill the reservoir and repaet the process until the fluid coming out of your hose is clean. It doesn't take long, except for your first try. My first try took about 30 minutes. I then did my F150 right after and it took about 15 minutes and did it totally on my own. In fact the F150 was easier than the Windstar b/c of the connection position for the return line on the reservoir is in a better position.
Old 04-12-2008, 01:36 AM
chasealley chasealley is offline
Re: Power Steering
OK guys, haven't been around for a while but thought I'd chime in because I just did a little work on this myself.
First, the Ford procedure is to remove the relay, use a second person to crank the engine. I found this worked well, and fast. The advantage is that you use the pump to generate a little pressure. Hopefully you'll run a couple quarts through the system. Ford says to run it until the fluid runs clear.
Now, when I bought my car the PS line had just been changed so it had new fluid in the last year (but not flushed). I checked it and it smelled burned so I did the flush. I'm conscious about dry steering but like clockwork, one year later it smelled burned again even though I used Mobil1 synthetic.
My suggestion is not to do the turkey baster method because it will take you forever to actually flush the system because you are removing some, adding new, mixing it toghether and then removing some of the mixtues each time. No one would do that with engine oil so I wouldn't with PS either, especially when the flush is so simple.
I recently wrote an article on this. I'll see if I can find it and post a clip.
