Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-28-2007, 10:52 PM
mike avery mike avery is offline
Exclamation Evap Leak
My engine light recently turned on, so i checked the code and it said that i have a small evap leak. I heard that the most common problem is caused by the gas cap, so i replaced the gas cap and erased the old engine code and the code came up again within a day. I know where the evap lines are and where the evap vapor canister is located but what i don't know is where the " small leak " is located. Is there any kind of tricks or tools that are avaliable to help locate this kind of problem? Any suggestions are appreciated.
Old 11-28-2007, 10:59 PM
reekor reekor is offline
Re: Evap Leak
Smoke machine.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 11-29-2007, 09:01 AM
Re: Evap Leak
What is your suggestion on where to buy a decent smoke maching that isin't going to cost me an arm and a leg? I have already checked local auto stores as well as a few online stores and if they can get it, it will cost around $1,000 doesn't sound right to me. Let me know, thanks.
Old 11-29-2007, 09:38 AM
Re: Evap Leak
They can cost alot more then a $1000. Try your luck on Ebay if you really want one. If you only work on your own cars it might be cheaper to take it to someone that has one. A smoke machine might have a hard time paying for itself if its only used at home.
Old 11-29-2007, 02:52 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Evap Leak
I agree with reekor on this. A shop will charge you an hour or less to diagnose for you. That is a lot cheaper than purchasing a machine.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 11-29-2007, 10:20 PM
Re: Evap Leak
Thanks for the advise. It definitaly helps to get the knowledge from somebody else that doen't sugar coat things. Didn't really know the cost. Know i know. Off to the shop, Thanks.
