Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-28-2007, 09:16 PM
BigLou101 BigLou101 is offline
caprice suspension
ok heres the skinny on my problem
my 91 caprice 350 seems like it might have a problem but im not sure if its just something normal and im paranoid. the passenger rear tire seems to be awfully close the the half fender/ wheel well. its got about 3/4 inch clearence where as the driver side has a good 2.5 inches of clearence shjould i be worried any advice would help thanks in advance
Old 11-28-2007, 10:24 PM
Nalayah Nalayah is offline
Re: caprice suspension
It may be a blown strut. If you have a friend or any mechanics with a four point lift (not sure of the exact name), take it to them and have it looked at. Sounds like a seal went bad in the strut or something.
But I'm not too good with suspension. It'd be best to take someone elses advice if anyone else does post.
Old 11-28-2007, 10:46 PM
GreyGoose006 GreyGoose006 is offline
i would look at the rear end itself.
it could be off center, or you could have an axle that is about to break.
Old 11-29-2007, 12:55 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
These cars don't have struts. They use shocks and springs.
If the car is leaning, it may be a weak spring. It could even be different sized tires - do both match?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 11-29-2007, 08:39 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
As a super quick check to see if the rear is somehow cocked, do the "follow me" test. Have a friend follow you on a straight level road, a 1/2 mile should do it. Not too closely, he has to see if the car is "crabbing" to one side. Have him look for the front and rear wheels tracking in the same line.
Then get the car on a lift if possible and see if a lower trailing arm is bent, that would be my best guess. You may be able to jack it up on the driveway, use jack stands if you do. Look for a shock leaning at a weird angle, a kink in the lower trailing arm or a broken bolt in one of the upper arms.
Bob
Old 11-29-2007, 10:25 AM
463's Avatar
463 463 is offline
It could even be different sized rims - do both match? eg. backspace or offset.
Old 11-29-2007, 10:29 AM
463's Avatar
463 463 is offline
if the car is stock it will call for a p225/70/15 tire or check the drivers door for the correct tire size.
Old 11-29-2007, 06:45 PM
j cAT j cAT is offline
check the rear end support arms.the ones on top most likely rusted or the bushings are bad seen this before on this body .
Old 11-30-2007, 05:20 PM
the tires all match even though they are a little bigger than called for. its not crabbing. im not sure what it could be nothing seems to add up other than that space the car rides perfectly. not an abnormal noise or anything.
Old 11-30-2007, 07:02 PM
silicon212's Avatar
Confoundingly Lucid
If the car is otherwise in good shape, doesn't pull or show other signs of suspension issues, then check your body mounts. It's possible that one may have failed, allowing the body to sag on the frame at that point.
Old 11-30-2007, 10:10 PM
thanks Silicon ill give that a look ill have it up in the air tommorow if indeed its broken any idea on a cost to have it fixed
Old 12-01-2007, 12:20 AM
blackEyeSSFly blackEyeSSFly is offline
if you notice our cars have that problem , just like the wheels are not centered in the rear well...you may want to check into extended trailing arms to center them both correctly...
Good Luck
Cardomain http://www.cardomain.com/ride/2143750
Success is to be measured not so much by the position that one has reached in life as by the obstacles which he has overcome
