Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 11-28-2007, 07:16 PM
lilcrc lilcrc is offline
Send a message via AIM to lilcrc
Bouncing Temperature Gauge
(If a similar thread has been posted, I apologize.)
I have a 97 Wrangler Sport with the 4.0 and 5 speed. A couple of weeks ago, I was driving to work and noticed the temp gauge was a tiny bit higher than usual.. almost to the 210 mark, then it started dropping, to about halfway between the 150 and 210 marks. Then it slowly moved back to the normal spot, a needle's width from the 210 mark.
It hasn't done that since, until today. Did it driving to and from work. Can't find any leakage, no antifreeze smell, coolant level is fine.
BTW, the water pump was replaced (again) about six weeks ago, the thermostat and temp sending unit were replaced in April. Other than this suddenly wacky gauge, it runs fine.
I'm totally lost with this. Can someone please help?
Old 11-29-2007, 10:48 AM
terrymason terrymason is offline
Re: Bouncing Temperature Gauge
Why was all the other stuff replaced? Did replacing that stuff fix the problem at the time?
I doesn't sound like the gauge is bad, it sounds like the engine temp is really changing.
Old 12-03-2007, 12:41 PM
4x4grey88's Avatar
4x4grey88 4x4grey88 is offline
Jeeps normally run temperatures around 200 F so it is not reading high. If the gauge is fluctuating as much as you are stating it could be a bad sensor and or thermostat. I would check the sensor first.
www.jeepforum.com; www.socalultimate4x4.com
1998 Wrangler (replaced my 88 XJ)
21' Mini Winnie (replaced my Pace Arrow)
