Old 11-28-2007, 01:46 PM
OSUCowboy27 OSUCowboy27 is offline
Add Methanol To Fuel?
I have a 1990 R-1500, 5.7L and want to add alcohol to the fuel. Fuel with any concentration of ethanol is not available in my area so I want to use methanol. I can get 99.9 % pure methanol for free from where I work. The problem that I have is that I do not have a manual so I do know what the max concentration is for MeOH. I assume that it is 3% by volume. I also plan to add some lucas fuel treatment at the same time.
Old 11-28-2007, 04:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Add Methanol To Fuel?
Check you owners manual, I'm pretty sure they say specifically not to use methanol.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-28-2007, 07:37 PM
As stated in my original post, I do not have a manual. I am pretty sure that the max is 5% Methanol but am not sure. I also think that I can run up to 10% Ethanol and 20% MTBE.
