Old 11-28-2007, 01:15 PM
garync1 garync1 is offline
2001 door frame sticker missing correct Tire psi
Just went to look for my door frame sticker for recommended tire pressure and it did not come with one or it fell off not sure which one.. Book says it should be there. Not finding what tire pressure it should be.. Read a alert Goodyear put out a while back about using car manufactures recommended tire pressure. I already knew about max psi rating on a tire. I have been putting 35 psi in the tires but just wanted to check. Not sure if I saw it on the van somewhere or habit. I know the Ford Freestar runs at 35 psi by its door sticker. Not sure what the Windstar recommended psi is.. This is a 2001 Windstar. Does every one else have the door sticker.??? Gary
Old 11-28-2007, 05:29 PM
catvents catvents is offline
Re: 2001 door frame sticker missing correct Tire psi
I have a 2001 model and it has a door sticker indicating 35 psi for front and rear tires.
Old 11-28-2007, 06:57 PM
Thanks.. is yours on good or starting to peel off.? I also think it has the paint code on it as well.. Mine must of came off. I don't see a mark area were it use to be but I do wash my door seal area every time i wash the van.. Just can't recall. It bugs me.. Well I do work on a few automobiles. So I might be trying to remember something that just was not there. Or at least when I bought it... Thanks again..Gary
