Old 11-28-2007, 12:54 PM
alltimes alltimes is offline
will not turn over
2000 grand am se 2.4 with 165,000 miles.
This car has and was running great. One time I went to start it and as I turned the key my hand slipped of the key as soon as it started to engage. Just barely bumped the starter (had a wrist injury at the time).
Went to start it again and it would not turn over. I can turn the key on and bump start it at the starter with a screwdriver, but it will not turn over with the key. I replaced the ignition switch thinking that may have been the problem but it was not. I have also done the pass lock thing. Could it be the starter since I can start it by bumping the starter with a screwdriver?
Thanks
Old 11-28-2007, 01:08 PM
inafogg inafogg is offline
Re: will not turn over
hello no i think ur starter is ok.try starting in neutral as maybe its not fully in park all the way.good luck
Old 11-28-2007, 01:27 PM
Thanks. I tried that just now but no luck. Oh well. Beats me.
Old 11-28-2007, 04:57 PM
hello alltimes sorry that did'nt work out.with all the things you've already done im sure you did the battery ck connection things? i checked recalls didnt see much in this area.maybe someone else has/had this type of problem.just start checking connections good luck
BTW did check nss (neutral safety sw.)???right
Old 11-28-2007, 08:43 PM
Thanks. I really appriciate the suggestions. I dont think it is the nss. My understanding of the switch is,,,, if the switch is faulty it will not start in park but it will start in neutral.
Actualy I misstated something in my original post. I did not replace the whole ignition switch. I replaced the ignition cyclinder only. Maybe I need to replace the whole switch. Anyways Thanks! I will keep plugging away on it.
Old 11-29-2007, 01:22 PM
im thinking when ur hand slipped u may have created an arch that shorted some thing out anyway good luck mike
