Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 11-28-2007, 07:18 AM
DaveBurke25 DaveBurke25 is offline
2001 ZX2 Battery Light
Question for you all...
When I get my 2001 ZX2 up to about 4K RPM (I live near the mountains - it has to be done), my battery light will flicker on and off. Once I drop back down below 4K RPM, the battery light turns off.
The car is an automatic, with about 95000 miles on it. The battery is less than a year old. This problem has been going on for about 2 months now, but the car has never failed to start. I have even ran my radio off the battery for over an hour (to see if it would die), and still the car started right up.
This confuses me, because based on my limited knowledge of cars, the battery would be used LESS when the car was going faster... someone help me!
Dave
Old 11-28-2007, 11:28 PM
Markb873 Markb873 is offline
Re: 2001 ZX2 Battery Light
Have the alternator bench tested at a major autoparts store, it's free, could be a bad regulator.
The cars on the lawn:
2000 Kia Sportage
1993 Chevrolet S-10 Blazer
1975 Radio Flyer Wagon
Old 12-05-2007, 04:00 AM
Davescort97 Davescort97 is offline
Escort guy
Actually the battery light registers the condiltion of the generator (alternator) not the battery. It could be one of two things. At higher engine speeds the belt could be slipping on the alternator pulley. Check belt tension or automatic tensioner. The second possibility is that the brushes are worn so much that the springs can no longer hold them against the armature with enough force to conduct current at a higher engine speed. Check for glazing on the belt. A sure sign that the belt is slipping. Markb873 had good advice. Take it off and get it bench tested.
