Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-27-2007, 09:01 PM
birdyards birdyards is offline
Question 94 4 runner cold start problem
I have a 94 4 runner 4wd v6. I am having problem keeping the idle in normal rpm when the engine is cold. It will start but rpm will drop fast and die if I don't put gas to keep the engine running. However, it will run fine after the engine warm up. Anybody experience same issue or know what is going on?
Old 11-27-2007, 10:40 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 4 runner cold start problem
Welcome to the AF!
Check your cold start injector/injector time switch, and your ECT sensor.
Try cleaning your throttle body:
http://www.4x4wire.com/toyota/mainte...throttle_body/
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-28-2007, 03:00 PM
Just cleaned the throttle body but it still acts the same... developing skill to test the rest of the systems you have mentioned... thank you for the help and I'll keep you posted.
