Go Back   Automotive Forums Car Chat > Mitsubishi > Galant
Old 11-27-2007, 08:01 PM
Inman Lanier Inman Lanier is offline
Engine Coolant Drain Plug Location???
I have a 2003 Galant 4 cylinder. I wish to R&R the coolant - the tech manual talks about removing the "Engine coolant drain plug" but doesn't specify a location. Anyone know where it is? Thanks
Old 12-02-2007, 11:06 PM
mike avery mike avery is offline
Talking Re: Engine Coolant Drain Plug Location???
The coolant drain plug on your car will be located on the right side or passenger side of the radiator, it will also be on the bottom. You should be able to see it if you look strait down from the engine compartment. Also consider changing the thermostat while you are draining the coolant if ot hasen't been replaced recently.
