Old 11-27-2007, 06:46 PM
sdale11 sdale11 is offline
transmission Question
I have a 2004 ford taurus 24 valve 3.0l
ok were would the trans.. pump be at I think this is what's wrong with my car
it will not go into gear it worked fine then just out of nowhere it quit, it will not go into (R) or (D) I just don't know but some friends said it was the pump plezzz help thanks
Old 11-28-2007, 12:56 AM
tripletdaddy tripletdaddy is offline
Re: transmission Question
I'd investigate whether your shifter is even shifting the transmission into the gears, has it come loose or something hoping it's that and not worse. Does it shift differently. Someone else would have to describe on that vehicle where and what the shifter attaches to at the trans. What I am familiar with is a cable that goes to the top of the trans to a lever. Good luck
Old 12-01-2007, 02:22 AM
mwt47's Avatar
mwt47 mwt47 is offline
I would take it to a transmission shop and have the codes read on a correct reader.
The standard OBDII reader will not cover all codes.
The pump is inside the tranny and the transmission has to come out for any inspection/work to be done on it.
Mike
