Old 11-27-2007, 12:33 PM
Larryzzo Larryzzo is offline
92 454 throttle position sensor
I have a 3500 1 ton with a 7.4 that doesn't want to stay running when it's cold. I was told to try a new TPS. Is it as simple of a change out as it looks, or are there any tricks to it?
Old 11-27-2007, 02:59 PM
maxwedge maxwedge is offline
A990 racer
Re: 92 454 throttle position sensor
More than likely that is not your problem, I would scan it and look for a coolant temp sensor that is faulty.
Old 11-27-2007, 06:55 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Originally Posted by maxwedge
... look for a coolant temp sensor that is faulty.
I had the same problem with my 92. Bought the truck last December, but trouble didn't start to show until it got really cold in January. If I can simplify the function: the CTS acts like a choke on a carb when the engine is cold. You can also check the CTS with an ohm meter as there are specific resistance values for any given temperature. At 20 deg F mine was reading like it was a warm summer day, so the truck wouldn't start in January. Bought a new Delco CTS and averything was fine, sort of. Ocassionally the truck would run rough at idle, but wasn't throwing any codes so I changed the module, ignition coil, then TPS. All the old parts were original 92 parts and the truck ran better with every change. Now it runs perfect, and even gets half decent fuel mileage!! On SBC engines the CTS that you should be concerned about is near the thermostat housing, but I don't know where it is on the BBC as I've parked my 454 K3500 at another property. There's another CTS in the SBC head, but that one is for the temperature gauge.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 11-28-2007, 08:13 AM
Sounds like the same problem. The truck runs great after it gets up to temp. I wont be driving the truck much this winter, but still want it fixed. I see there's a sending unit in each head. Are they both coolant temp. sensors? A new one is cheap enough ( about $14 ) so I'll change both, but I want to make sure I'm putting in the correct part. They look the same. Thanks for the info.
Old 11-28-2007, 10:07 AM
2000CAYukon 2000CAYukon is offline
Looking at my factory manuals for 1990, it shows the Engine Coolant Temp Sensor in the intake manifold not the cylinder head. Things could have changed for 1992 but I doubt they moved the CTS.
//2000CAYukon
Old 11-28-2007, 04:25 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Agreed. It should be on the intake or the thermostat housing for any year. The one in the cylinder head is only for the temperature guage on the dash.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
