Old 11-27-2007, 07:59 AM
Windstartranny Windstartranny is offline
98 Wndstar won't shift
My 98 Windstar won't shift to higher gear when the weather gets hot. When I shut off the engine and restart, all is well. Any suggestions? Thanks.
Old 11-28-2007, 07:53 PM
wiswind wiswind is offline
Re: 98 Wndstar won't shift
A high failure item that is not expensive is the Transmission Range Sensor (TRS), aka Neutral Safety Switch.
It is mounted on top of the transmission case, under the air intake hose.
The cable from the gear selector connects to it.
Also, make sure that the Fluid is fresh......it should be changed AT LEAST every 30K miles, using Mercon V ATF.
With the vehicle on level ground, and the engine at idle, in PARK, check the fluid level on the Transmission Dip Stick......add fluid as needed.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-29-2007, 12:05 AM
Thank You Very Much for your reply. I will check it out.
Old 11-29-2007, 12:12 AM
From Windstartranny to Wiswind
Thank you Very much for your reply. I will check it out. Much appreciated!!!
