Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-26-2007, 08:51 PM
willy22 willy22 is offline
2001 Rodeo thermostat
Is there anything special I should know about replacing the thermostat in a 2001 Rodeo V-4? My daughter owns one and her heat is not working.
Thanks in advance!
Will
Old 11-27-2007, 12:55 AM
Ramblin Fever Ramblin Fever is offline
Re: 2001 Rodeo thermostat
Make CERTAIN to use an OEM Isuzu replacement ONLY! VERY important!
1997 3.2L V6 Rodeo
32" Yoko's, 16x8 MB Wheels, 2" lift, Brushguard, KC Fog's, Loadwarrior Rack
On it's way to 185k strong
2004 3.4L Tacoma TRD off-road 4x4 Double cab
32" Yoko's, Westin Bull-bar, KC Fogs 60K miles
Old 11-27-2007, 08:30 AM
srpope80 srpope80 is offline
Maybe I'm a little confused..... If the heat is not working, wouldn't that be caused by the heater valve and not the thermostat? Is the truck overheating? If not, I would look elsewhere besides the 'stats....
Old 11-27-2007, 07:42 PM
Thanks. Is the T-Stat located in the same place as on most vehicles? My daughter lives out of town and I need to know what I have to take to replace it.
Thanks again,
Will
Old 11-27-2007, 08:19 PM
2000izusu 2000izusu is offline
if you have the 3.2 you have to take the intake manifold off to get to it. if you have a 2.6 i don't know where it is? mike
2006 liberty 3.7 6speed manual
1999 cherokee classic 4.0L
1991 wrangler yj 2.5L
2001 caravan 3.3 auto
1995&1992&1994 camry 2.2L SOLD
1991 silverado 1500 SOLD
2000 rodeo SOLD
Old 11-27-2007, 11:25 PM
My '97 3.2L V6 engine is different then yours; mine's right out and up front, on your's you will have to take of the manifold.
A bad thermostat *could* cause heating/cooling issues; so can low antifreeze level, air in the system, etc.
1997 3.2L V6 Rodeo
Old 11-29-2007, 02:09 AM
trooperbc's Avatar
trooperbc trooperbc is offline
no heater valve; coolant is always flowing thru the heater core. heat happens when the flaps lift off the heater core so the air circulating gets heated and directed into the cab.
no heat could mean
those flaps aren't operating properly.
or the coolant system circulation is disrupted (hindered)
or the coolant system isn't getting up to temp (stuck open thermostat)
have to do some checking and give more info to narrow it down.
//bc
1992 trooper 3.2L v6 sohc automatic...as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
