Car is low
Hello, I have a 96 Honda Accord LX 4dr. My boyfriend changed the springs to racing lowering springs & now the car is too low (he told me it gives the car better handling). I am tired of the bumper hittiing the ground over potholes and driveways. I was told by him to get bigger tires to raise the car. I currently have 15in tires. I wanted to get 18s or 20s. 1 mechanic told me not to to get bigger tires because the tires would then rub on the car when there is heavy weight inside the car. What do you guys think???? Thanks!!!
Danita |
Re: Car is low
Why not just tell him to put the original springs back in the car, and if he wants to mess with a car do it to his own car. But on a honda you're never going to fit 20's in there and be able to drive it at all even stock height. Largest fwd wheels I've seen on honda is 17 and sometimes 18 but they don't have the room for anything bigger. Best bet if you're tired of the bumper dragging on stuff is to tell him to just put the original springs back then give him a smack down for messin with it in the first place.
Re: Car is low
You can fit 19's on an accord, but you would probably have to go back to stock ride height to do that.
Tell your boyfriend not to mess with your car anymore. He clearly doesn't know what he's doing.
Dr. Disque - Current cars: 2008 BMW 135i M-Sport 2011 Mazda2 Touring Past cars: 2007 Mazda 6S 5-door MT 1999 Ford Taurus SE Duratec |
Re: Car is low
You'd be lucky to get a lift of .5" with it lowered without tires rubbing. Re-installing the stock springs is definately the way to go... unless he made the lowering springs himself with a smoke wrench
.Also, the last number in a tire size isn't the size of the tire, it's the size of the rim... My 15" tires on my truck are bigger than any 20" you'll see on a car. You would be able to go with a larger tire and keep the 15" rims.
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
