Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 11-26-2007, 06:41 PM
caniborrow50cnts's Avatar
caniborrow50cnts caniborrow50cnts is offline
Send a message via AIM to caniborrow50cnts
nuisance whine coming from speakers
Seems to be more of a general issue, but is quite annoying. All of a sudden one day, I think I hit a bump in the road and since then a kind of whining sound comes out of every speaker. Its not real loud, and it only occurs when the engine is running. Also, the pitch changes with acceleration. If I turn the volumn up, its noise is mostly covered.
I've done most of the troubleshooting already. I swapped out the radio with another similar one. The only factory wires still being used are both positives, ground, and antenna. The amp is soley connected by RCA wires, and an amp remote wire is connected directly to the radio. All wires radio related have been checked for bad or grounded connections without it being fixed.
So to simplify, I have found an alternative way to connect each and every wire except the ground and positives. Could something somewhere in the car cause this to happen? Has anyone heard or had to fix this before?
72 Beetle - trashed
88 Escort EXP - dumped
92 Talon - sold
97 Eclipse RS - still own
99 Eclipse GST - still tearing up the asphalt
Old 11-27-2007, 12:33 PM
JoeShmoe's Avatar
JoeShmoe JoeShmoe is offline
Send a message via AIM to JoeShmoe
Re: nuisance whine coming from speakers
Have you tried using a ground loop isolator? Goes from stereo to amp via the RCAs.
'98 Contuor SE, 2.5 V6 Auto Silver
'08 Altima 2.5S, Auto Super Black
Old 11-27-2007, 07:09 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Did you run the RCA wires directly alongside the amp power wire? I had a problem with whining when I got my car, but it was because I had the remote turn-on connected directly to the battery. But if you ran the power wire near the RCAs, the RCAs will pick up some interference.
95 Talon TSI AWD
97 Eclipse GST
Old 11-27-2007, 10:23 PM
JoeShmoe's Avatar
Old 11-28-2007, 02:16 AM
It sure is tedious. I just see no reason why it only does this when the car is running. None of the wires are running next to each other unless it is a pair (left/right rca or +/- speaker). I have even disconnected all speakers and used a 4" mid speaker and also used a different amp. If I can't figure anything out soon, I think I am going to swap the entire system from my other eclipse then replace part at a time to test it. Could it some how be possible that electromagnetic interference or a bad ground somewhere else in the car flows through the radio when the car is running? I've never heard of that unless there is a faulty wire in the radio itself.
72 Beetle - trashed
92 Talon - sold
Old 11-28-2007, 02:40 AM
It could be a bad ground somewhere, but I'm betting on interference between the RCA and power cables.
95 Talon TSI AWD
97 Eclipse GST
Old 11-28-2007, 06:54 AM
JoeShmoe's Avatar
Doesn' necesarily have to be the power cables for the amp. Even wires running to the fuel tank can give emi, how about this. If you have power windows, flicker the switch up and down while the car and audio are on. If its a draw then the speakers will sound even worse, if they do then sounds like you have a nasty draw somewhere.
Oh, are any of your wires melted together? (anything running under your carpet)
Old 12-09-2007, 07:00 PM
As normal with any car issues I come across, few are fixed on the first attempt. I've narrowed it down to something related to the engine. Since it only occurs when the engine is running. What parts in the car are switched on and increase with the engine? The obivious would be the coil packs and tachometer. What else? Also, what does the voltage normally stay at while running? I've heard 14.7v, but mine runs around 12-12.5. It has a new battery and the alternator has been swapped. I don't remember if the voltage has always been that low, but it was low even with the amp disconnected. What could cause this noise to start? I hit a bump and the noise started. Let's say if I were to take it to a shop to search for the problem, how much would just the diagnosis cost?
72 Beetle - trashed
92 Talon - sold
Old 12-09-2007, 10:18 PM
Check all of the engine grounds to make sure one didn't vibrate loose or something.
95 Talon TSI AWD
97 Eclipse GST
Old 12-09-2007, 10:38 PM
are you refering to the wires that connect directly to the engine, a sensor, or something that controls the engine? There are only two wires that connect directly to the engine from the frame. I would also like to point out, this started november 06. I have changed out the engine since then, and it still happens. How likely is it that a sensor or gauge is causing this? I didn't swap every part, just the ones on the engine itself. The wires are all the same.
72 Beetle - trashed
92 Talon - sold
Old 12-09-2007, 10:44 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I doubt its a gauge or sensor... +1 for a bad ground. I guessing something under the hood. Check all the grounds you can find. And the one for the amp.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-09-2007, 11:08 PM
Try disconnecting your remote turn-on for the amp and see if it goes away.
95 Talon TSI AWD
97 Eclipse GST
Old 12-09-2007, 11:38 PM
I have confirmed there are no loose grounds in the engine. Also, there are no issues with the speaker system. I took another battery and connected the amp and radio to it directly, started the car, no noise. I cannot find any melted wires. I pulled every fuse/relay I could, to see if any of them broke the circuit creating the sound. I am a couple of days away from swapping every sensor with my other eclipse. nothing obvious is helping. The only thing that would make sense is a wire voltage changes with the engine. I will bolt another ground wire to the block to see if it makes a change though. A bigger ground wire should pull more electric. Path of least resistance right?
72 Beetle - trashed
92 Talon - sold
Old 12-10-2007, 12:28 AM
Try what I said. Disconnect JUST the remote turn-on and see if it goes away. My bet is that it will.
95 Talon TSI AWD
97 Eclipse GST
Old 12-10-2007, 12:34 AM
done that, didnt work
72 Beetle - trashed
92 Talon - sold
