Old 11-26-2007, 05:41 PM
Crystalion Crystalion is offline
Bigger Tires
Someone I know has 255 75R 15s on rims for my 2000 Cherokee sport. They are a little wider than the stock 235--will this cause any problems--also the rims are aftermarket and look much better than the stock-Pros and Cons are accepted--Chris--Thanks
Old 11-26-2007, 06:13 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
Re: Bigger Tires
Best way to tell if they'll fit is see if your friend will let you borrow one and mount it in the rear and check all clearances, then mount it in the front and check all clearances when the steering wheel is turned from one side to the other to make sure there's no rubbing. They may be wider but it's only 2cm difference in the tire, for aftermarket wheels the backspacing might have been adjusted enough to provide plenty of clearance.
Old 11-29-2007, 12:14 PM
citizen@large's Avatar
citizen@large citizen@large is offline
Re: Bigger Tires
Sure they'll fit. The tires I mean. The different wheels will determine the clearances.
hmm... I think that's exactly what you said Dave.
Old 11-29-2007, 09:06 PM
Re: Bigger Tires
You should be fine as the stock factory wheels and rims are 15x8 and 235/75/15 which has the tire under nominal pressure at ~8 inches wide. I put 31 10.50x15's on my jeep before i lifted it and the would only rub a little at full turn.
Old 11-30-2007, 03:24 PM
Re: Bigger Tires
^ Really Dave? Hmm... I've got a set of 31x10.5 BFG MT's that my girl wants on her rig. I thought she'd need around 2 1/2"- 3" of lift first.
Did you put them on the stock rims?
Oh, sry for the hijack.
Old 12-01-2007, 09:26 AM
Re: Bigger Tires
The wheels that are on my jeep aren't the stock ones but look similar. And yes they did fit but I didn't drive it around like that just long enough to drive it home and put the lift on. I was able to clear them with 2" spacers/blocks, if you're looking for a cheap lift take a look at the "ba$tard kit's" like on www.lunghd.com website where you repack the rear leafs and use GC front coils to lift it 4 inches. That's what i've got running now except the coils I've still got the 2" spacers up front so back sits a couple inches higher than front. One word of warning if you do decide to lift it like he says the shocks he recommends using will fit but you will have to swap the bushings and barpin's which is not an easy task.
Old 12-01-2007, 09:43 AM
Re: Bigger Tires
Just wanted to add the tires are Yokahama and the rims are just some flashy version of the stock wheel. Question --If you were going to put an "all around" tire for the Cherokee without going overboard what would you recommend ?? I need tires soon maybe some months and would like to upgrade but cash as usual is a problem.
Old 12-01-2007, 10:07 AM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Bigger Tires
For the record, the stock tire as delivered is a 215 or a 225/75-15.
The 235/15-15 is 29" in diameter.
The 30 is 29.6" or so in dia.
The taller the tire, the more off-road clearance. However you will loose torque and most of the time loose gas mileage. True off-roaders regear the front and rear to take advantage of the taller tires (32, 33, and 37s).
If cost is a major consideration, stick with the 235/75-15 or the 30. A set of Goodyear or BFG will cost you $450 to $500 after the taxes and service. That is if you reuse the stock 7 inch x 15 stock rim. There are cheaper tires, but you get what you pay for.
If looks and style are also important, add that in is as determined by your expendable income or budget. For off-roading, black "steelies" should be considered.
Tip: most of the "Forest Service" or "Park Service" garages use the 235/15-15 on the service Jeep Cherokee. This size is available in all-terrain or mud-terrain tread styles.
Here is one with 235-15, stock rims and a two inch lift.
Old 12-01-2007, 10:51 AM
Re: Bigger Tires
That's what I'm talking about right there guys. Brass tax if you will. Thanks.
So, yeah.... 31's in mind for her XJ. Already have a set of '95'ish rear leaf packs from an S-10.
Some springs for the front are in order, but exactly which ones are yet to be decided. I need to get her right in the 2"-3" range to avoid having to use an SYE just yet, along with all the steering issues involved with going higher than that.
Grand Chero coils huh? Do they go right in? What model Grand, year(s)? 4"'s Really? I thought it was more like 2"???
I've heard the F-150 solution, -NOPE. I've also heard about using T-Bird coils along with the top of the strut as an adapter-plate, but have yet to nail the years down yet.
Old 12-01-2007, 06:06 PM
Re: Bigger Tires
Dave! Aloha! C'Mon guys! *BUMP* ~ ed
FRED!?!?!????
Old 12-02-2007, 08:36 AM
Re: Bigger Tires
Thanks for all that good info-I had thought that the tires on there were an upgrade but wasn't sure. I'll probably just buy a good 235 and try to clean the rims up. They look painted white but are flaking. Thanks again. My Cherokee almost looks like the Forest Ranger version now .LOL
Old 12-02-2007, 10:04 AM
AlohaBra's Avatar
Re: Bigger Tires
Here is picture with two Jeeps. The one in back is stock with 225-15 tires and the one in front has 235-15 with a two inch lift in front and about 2 1/2 inches in back. I would use a 30-15 for my purposes because I don't want to regear or buy new wheels. IMO, the 31 tire needs an 8 inch rim for the tread to be completely flat.
I have used the two door many times off-road including the Jeep Jamboree at Big Bear 2007. I have a transfer case skid plate and a front diff skid plate for protection. Stock driveshaft and transfer case dropped.
Old 12-02-2007, 10:24 AM
AlohaBra's Avatar
Re: Bigger Tires
Hey Citizen...
I used a Rocky Road two inch lift kit. Then I took out the rear sway bar (not needed usually). I also removed all the leaf spring clips except one on each side (for more leaf flex). I also replaced the rubber bushings on the front sway bar with urethane one for more control up there. The bump stops in the rear were spaced down about an inch also.
As far as driveshaft vibes, yes, I had them. So, I did a home brew 1'" TC drop that cured it.
Since the lift, I have done about a half a dozen trips in various off-road parks and national forest trails. I works pretty well, once you disconnect your front sway bars and air down to 15 psi. The last one required an 8 hour drive each way on the interstate. Plus, I had to do an AC compressor replacement on the road in the hotel parking lot. A lot of work on that trip, but it was fun to do at least once.
I have no rubbing due to the smaller tire. If I need new ones, I might consider a 30 or 31. Right now, I cannot afford to go "wheeling" due to the price of gas and the distance that needs to driven to go off-roading.
BTW...thanx for keeping up the Jeep chats....
Old 12-02-2007, 12:08 PM
Re: Bigger Tires
If I wanted to add a lift kit --2" sounds right -does someone know of a good off the shelf one. Mine is a 4 door but is in great condition and Id like to do something to it. The 2 door you have in the pic looks great.
Old 12-02-2007, 03:38 PM
Re: Bigger Tires
Crystalion-
You might get yourself a little mixed up calling it an "add a lift kit"...
What you're after is a '2" Budget Lift/Boost'.
While there are budget kits that contain an add-a-leaf, you'll generally want to stay away from these as they tend to fail rather quickly and let the rear sag prematurely.
That being said, as Aloha mentioned in his last post, many folks find the Rocky Road Outfitters kit to work quite well for them.
This is the XJ/Cherokee Page-
http://www.rocky-road.com/xjsus.html
And this is direct to the 2"-3" Budget Lift they offer-
http://www.rocky-road.com/xjbudget.html
2" Kit, Shipped to VA...
Rocky Road Outfitters Shopping Cart Contents (nothing is final until you submit your order) item# item description unit price u/m qty cost adjust quantity here XJ7029 XJ Budget lift-2bpelift $139.00 ea. 1 $139.00 increase decrease remove Continue to Shop Refresh Display Go to Checkout Empty your Cart Order Subtotal: $139.00
  • Your IP Address and 'ship to' address are recorded as part of your order. Stop now if you are attempting to use an unauthorized credit card! ALL unauthorized users will be reported automatically to the FBI & Interpol. Please note: Shipping on your receipt is an estimate only. Limitations of an online order system may not reflect the need to ship an order in multiple packages, special packaging considerations, or oversize rate requirements.
    ARB Bull Bars ship by Truck Freight for which an online order system cannot produce a correct ship estimate. Please reference the US rate chart map found on our webpage.
    International customers: UPS, DHL, and US Postal GLobal EMS are the ONLY options available. We will research and select the least expensive carrier for your order.
    International customers please be aware: Your country may impose additional import fees or taxes to receive your shipment. Please understand Rocky Road has no control over this.
  • Shipping summary
    Box 1: 23.00 lbs. Shipping: $25.54
    Click here to change shipping options.
  • Utah deliveries subject to $8.69 sales tax.
  • Shipping weight: 23.00
  • Shipping cost is estimated.
UPS Gnd Residential [23860] Shipping: $25.54 Insurance: $1.39 Grand Total:$165.93 Please note:
1)All returns are ONLY elligible for in-store credit. No cash (or credit card) refunds.
2) If you must have your part for a certain deadline or are considering expedited shipping, please call to check stock before placing your order.
International order (except to Canada) will only be shipped by DHL, UPS, or Postal Global EMS service.
Secure Shopping Cart by: Americart®
ABOUT SSL CERTIFICATES
