Old 11-26-2007, 12:55 PM
jwalker1970's Avatar
jwalker1970 jwalker1970 is offline
Intake manifold coolant leak problem
RE: 1996 up 4.3L Vortec Intake manifolds
I had a vehicle come into the shop this morning with coolant in the oil.
No Misses at cold startup. No white smoke or "steam" out the tailpipe.
Vehicle had a distinct burning coolant smell.
Found Problems:
Coolant leaking externally burning on exhaust system.
Coolant leaking externally into oil system.
Cause: Defective Intake Manifold Gaskets
Fel-Pro has a "Perma-Dry Plus" gasket application for this application. The new style gasket is a rubber on steel gasket that won't crack and leak.
It's a bad idea to install the original hard plastic gaskets. They are the same material that GM used in the 3.1's and the 3.4's. (Lots of problems!!)
Old 11-26-2007, 02:56 PM
old_master's Avatar
Advisor/Moderator
Re: Intake manifold coolant leak problem
Very common problem, don't forget the RTV in the corners! Thanks for the info! Time to add another part to the "Don't use OEM" list.
Old 11-26-2007, 04:59 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Fel-Pro "Perma-Dry Plus" gaskets are by far, far superior than the OEM designs. I was almost ready to use the plastic gaskets again, but I found out that Fel-Pro makes these. If these were used OE from the factory, GM would have never had an issue with intake gaskets. They are well designed and will last.
