Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 11-26-2007, 11:48 AM
DAVE500 DAVE500 is offline
2005 4.3 Tachometer Wiring
Trying to install a tach on my 4.3 but there is no 'tach' label on the distributor (only c, d, etc). Where should I hook the green wire from the tach to the distributor (someone told me to splice into the white on the distributor but I do not want to 'fry' anything ) Any help would be appreciated.
Dave
Old 11-29-2007, 03:26 PM
Re: 2005 4.3 Tachometer Wiring
Am I oing something wrong - I can't access any replys
drs500
Old 12-01-2007, 08:35 AM
DFBonnett DFBonnett is offline
I don't think there were any. I have an '04 4.3 and looked in my shop manual for a diagram that would indicate a circuit which could be tapped for a tach signal. Nothing was relevant. Sorry.
Old 12-01-2007, 06:00 PM
I couldn't find it in my shop manual (Haynes) either, but there isn't any diagrams of engine wiring period. I wonder if it has a 'crank' position sensor (just put in a new 'cam' position sensor). There are ways to hook up a tach to distributorles engines, so... Thanks for your reply - Dave
Old 12-02-2007, 08:39 AM
Just in front of the leading edge of the oil pan, below the front cover and harmonic balancer.
Old 12-02-2007, 06:10 PM
Does the green tach wire go to the crank positioning sensor? Which wire? Seems like a weird place to run wires...
Old 12-03-2007, 01:33 PM
Is there a yellow wire? The wiring diagram in the FSM shows that to be the signal wire with a green wire being the 12 v reference and a purple wire being low reference.
Old 12-03-2007, 05:27 PM
It may take awhile to check the CKS wires because it is going to 'bodywork land' to have custom windows put in and a thorough 'de-dinging' and paint. Even though my buddy gives me a great deal, his bodyshop can take forever.
This may not be related, but do you know if you can put 235/75 16 inch tires on 8x16 custom rims? The tires are currently on the stock 6.5x16 wheels.
Old 12-04-2007, 09:41 AM
You might try an email inquiry at www.tirerack.com. They've been very helpful to me in the past.
Old 12-05-2007, 02:07 PM
Tirerack said hose tires would mount on any rim 6 to 8 inches wide, that'll save me some money. I'm getting off topic though, as soon as I get my van back I'm going to get that tach working!
