Old 12-05-2002, 03:18 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
Sun roof
How hard would it be to throw a sun roof into a CX(STD), and would an accord sunroof fit?
Old 12-05-2002, 03:31 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
It's much easier to put a pop-up sunroof in instead of a power sunroof.
Old 12-05-2002, 03:34 PM
oh yeh, is the wiring that hard, or what is it. And is the opo up one easy to install? Ill probly go to a junkyard and snag one outta there.
Old 12-05-2002, 03:44 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
slammed89civic would be the expert on this.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
iight
Old 12-06-2002, 10:48 AM
91civicDXdude's Avatar
what is a CX? the only models i've ever seen is DX, LX, STD, and Si. I thought CX was only a 5th gen?
Old 12-06-2002, 10:53 AM
Skeme1's Avatar
Skeme1 Skeme1 is offline
CX is the canadian equivalent of the STD model
Old 12-06-2002, 01:06 PM
dirtydx dirtydx is offline
are you sure it the CX and STD are equivalent?
I was looking through my canadian owner's manual, and the CX and STD are listed in different collums. The CX has a 5 speed, and can be purchased with auto. it says the STD holds less radiator coolant, .1 litres less to be exact. whatever difference that makes, i dont know...not sure what else is different, like interior options....
what was the topic again?
Old 12-06-2002, 03:20 PM
Skeme1's Avatar
dirtydx - you're probably right it was just an assumption i had...
cx =
Old 12-06-2002, 04:00 PM
they could be considered equivalent.. being the lowest trim and all..
but was the STD available in canada?
Old 12-07-2002, 12:00 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
about how much do new pop-up sun roofs cost installed and all? Isnt it only like $150 or so?
Old 12-07-2002, 01:38 AM
slammed89civic's Avatar
slammed89civic slammed89civic is offline
Send a message via AIM to slammed89civic Send a message via Yahoo to slammed89civic
actually the biggest bitch on installing a electric sunroof hacked from another car is actually justgetting it aligned perfectly and welding it on properly, i will take some pics of mine tomorrow, you cant even tell it didnt come with one, everyone thinks i have an sy.....when in reality it is actually a dx with EVERY single Si goodie....i call it the "Sx"i even have an "Sx" red sticker where the "si" red sticker would go.....it confuses alot of people, anyway, back the subject at hand....i used the Si headliner because i wanted it to look as clean as possable, so the hardest part was aligning it perfectly 000.01 of an inch off would make the sliding sun sheald not work, the wiring in VERY easy, my dx already had MOST of the harness, all the way from where the switch would be stock up to the top of the pass side A pllar, in my opinion pop up sun roofs look like shit....thats why i opted for the oem hack job
Old 12-07-2002, 08:43 AM
will a honda accord sunroof fit into a 90 civic h/b? Cause there is an electric one in the junk yard.
Old 12-07-2002, 03:20 PM
not a clue, look at the roof and see if it has the same curature.......its a possablitly, but unless your 100% sure i wouldnt do it, because it would suck to get half your project donr and find out it wont work
Old 12-08-2002, 11:43 AM
Hey can sumone post sum pics of their sunroof(int/ext. or installation if possible) I just need an idea of what do do and where to do it. thnx
Swap Moon Roof for Sun Roof david-b Exterior and Wheels 11 01-23-2007 04:17 PM
sun roof or moon roof driver6292 Monte Carlo 0 04-02-2006 03:58 PM
sun roof wind guard- suggestions taurus252 Cosmetics 2 05-18-2002 02:55 PM
I recommend not trying to place a hole through the sun roof. ned946 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 16 09-10-2001 05:33 PM
