Old 11-25-2007, 09:54 PM
aphinney aphinney is offline
Send a message via AIM to aphinney Send a message via MSN to aphinney Send a message via Yahoo to aphinney
heater quit working..
so my heater quit working out of no where. chekced the fuse and it is fine. replaced it just in case and still wont put out harm air...it is blowing good but just not hot air...what could be the prob guys..
TEAM AUDIOHYPE
1990 Honda Crx SI
Re: heater quit working..
oh this is on a 90 crx si
TEAM AUDIOHYPE
1990 Honda Crx SI
Old 11-25-2007, 11:33 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
heater core... check for plugging in core/lines, check thermostat, and check radiator cap for pressure leakage. should be around 13psi before it opens.
Old 11-25-2007, 11:34 PM
and i know this sounds stupid, but make sure the dial indicator is on hot instead of cold, and the wire in the back actually moves the door in the ductwork... sometimes they break and get stuck in the cold position.
Old 11-26-2007, 01:09 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Your heater has nothing to do with a fuse, that is unless you are saying that the fan wont blow anymore. The heater gets its heat from the engine via lines running into the car to the heater core. Follow the advice above. Ive seen plugged lines before, it does happen. But usually not if the heat was working just recently. A month or more of non-use could let crud build up in the line. Did you put the dial to cold after the last time it worked? The linkages could have disconnected and be stuck on cold.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
