Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 11-25-2007, 08:53 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
A Few New Pics
A few pictures taken this weekend @ Forest Park in St. Louis, MO. A couple @ the Great River Road in Alton, IL. St. Louis and Alton are 20 minutes from each other. (FYI)
The UR sticker is going to be taken off as soon as I get un lazy...
03 Molten Silve Spec V:Nismo SS;JWT BSR;Nismo CIA;Khumo Ecsta ASX Tires;Slotted Rotors;XS Header;Apexi WS2 Exhaust;Magnaflow Hi-Flow Cat;Nismo Coilovers;ESMMI;WRP IMS;WRP TBS;TB Port;WRP Grounding Kit
Old 11-29-2007, 01:27 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: A Few New Pics
nice nice. how far are you gonna go with the car? its at the level of cool DD right now. if your trying to keep it that way, i would only change out parts you already installed for better ones down the road(i.e. upgrade headers, ect.). theres no need to comprimise any more driveability. one thing you could do is get your car tuned on a dyno. find someone who has their own programs and see if you can get them to reflash your stock ECU for a little fatter torque curve and less dropoff at the top end. other than that your car is badass. (oh and get new rims too. something forged).
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 11-29-2007, 04:48 PM
ProZach626's Avatar
Re: A Few New Pics
Thanks for the compliment! I've worked really hard to mod the car, but still keep it clean and not cheesy.
As of right now, it is a DD. However, here is what I SHOULD have done by Spring:
Stop Tech Slotted Rotors (purchased)
Nismo Cams: 7whp (Purchased)
WRP Variable Exhaust Cam Sprocket: 4-6whp (Purchased)
SAFC Neo (purchased)
Eiback Front Stay bar (purchased)
Rear Sway Bar (Purchased)
WRP Grounding Kit (Purchased)
SS Braided Clutch Line (Purchased)
Rev Auto Torque Dampener(Rev Auto is supposed to give one to me for my help with R&D on solid Nylon Motor Mount Inserts)
Yet To Purchase:
JWT Clutch/Flywheel Combo (OR) Clutch master stage 3/fidanza flywheel
SS Stop Tech Brake Lines(On Xmas List, lol)
Hawk All Ceramic Pads
I also purchased a Spare Cross Member + Mounts and I intend on filling my current mounts with 90a Urethane. These will be more reliable than my ESMMI's, will allow for less motor movement, but they will be a lot less harsh on vibrations than solid mounts.
I plan on having a shop to my Clutch/Flywheel/Cams/Tune/SAFC NEO install for me with my tax returns. I have done everything else to my car myself, but as I said It's a DD and I'm not that advanced to do those mods.
By the end of summer, I'd like to have a CF trunk and my roof painted black, also. It sounds cheesy, but I've seen it done and it looks great.
The only cheap part I have to upgrade is my header. My XS exhaust was replaced with Apexi WS2. The header has never done me wrong. I don't think I'm going to replace it, but possibly ceramic coat it.
Old 11-30-2007, 11:44 AM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: A Few New Pics
pretty clean zach.....
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 11-30-2007, 02:59 PM
Re: A Few New Pics
a couple more comments.
dont get me wrong, theres nothing bad about the parts you used, but if your the kind of person to let good enough be, you would have left your car stock. theres always a better part to be had.
think hard about putting on a light flywheel. one missed shift could send valve spring retainers through your valve cover. your motor doesnt have much wiggle room in case of an over rev, and light flywheels make a small over rev into a big one. just a warning.
keep your sway bars proportional to stock, then add a bit of stiffness in the rear bar. that is, if stock are both solid or both hollow, dont add one solid and one hollow. beef up the rear sway bar stiffness either from an adjustable bar or a couple mm fatter bar. again though, beware of the consequences. if your rear end starts to step out, dont be a dumbass and let off the gas. thats how cars hit walls or other cars. in order to keep the rear end behind you in a FWD car, give more gas.
get some track time under your belt. even on a daily driver, it can help you tune your car so if you do get into an emergency maneuver situation on the street, you know how your car is gonna react, and what you can do to avoid bad things hitting you.
Old 11-30-2007, 04:44 PM
ProZach626's Avatar
Re: A Few New Pics
Thanks!! I've come along way, eh?
Old 11-30-2007, 04:52 PM
ProZach626's Avatar
Re: A Few New Pics
I understand what you mean, completely. I didn't take any offense to it. I'm just saying that I think the only questionable part in my arsenal is my XS header, which I really do stand by 100%. The rotors are low quality too, but I have the replacements for them sitting about 5 feet from me(400 dollar slotted stop techs). I just don't see a point in modding so early into winter, you know? The XS exhaust was shit, so I got rid of it. It's not even like I can't afford a Nismo header, or better replacement, but I really am satisfied with the XS header. I know a lot of people on b15sentra.net and myspecv.com that haven't had any problems what so ever, with the XS header. Other than that, I really do try to get everything top of the line. After a few bad experiences I've had (XS exhaust/rotors/etc) I really do believe that you get what you pay for.
I do appreciate your compliments, though, because I value this forums opinion. I know that if I had a really riced out car, I would hear it here, first..
I think I'm going to take the "Spec V" vinyl off of the brow of my car, this weekend, also. What do you guys think?
Old 12-02-2007, 07:53 AM
Re: A Few New Pics
i think........ YOU NEED NAAAWS!
Old 12-02-2007, 07:57 AM
Re: A Few New Pics
hey im working on a manual over-ride for the secondary runners, it should allow for a manual override of the ecu signal letting you apply the secondaries under WOT before 5k...... should give more flexibillity in certain situations where the motor is under load but your 200-1k rpm out of powerband
Old 12-02-2007, 09:20 PM
ProZach626's Avatar
Re: A Few New Pics
SAFC NEO lets you open up the secondaries, early. That's one of the things I'm going to play around with when I have the car tuned. I wouldn't think it would be anything but beneficial.
I've got a manual override for you... zip ties.. :P
I took the "Spec V" off of the front of the car, and the UR sticker. Thinking about going black with the calipers, when I get my new brake set up on.
Old 12-04-2007, 03:04 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: A Few New Pics
iirc, they did a dyno showing that opening the butterfly valves earlier did nothing. if anything, it would lower low end tq, and raise hp just a tad. you would be better off just leaving it how it is. search for secondary runner on b15sentra. you'll see what im talking about. i cant find it at the moment.
but if it does help ya, power to ya. just get it dyno'd and see if it helps at all.
one thing im confused about though, is why nismo cams? the jwt's are more agressive, and cheaper on the wallet brand new. and jwt makes both sets of cams, the nismo ones and their own from new nissan blanks.
oh, and before i forget, grab the wrp intake manifold spacer while you are at it. gives about 7whp. you even posted in it .
http://www.b15sentra.net/forums/show...ght=wrp+spacer
and grab a throttle body spacer. gives about 8whp.
http://www.b15sentra.net/forums/show...=intake+spacer
and like i said on that forum as well. i like it. nice and clean. simple, but effective.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 12-04-2007, 02:15 PM
Re: A Few New Pics
i understand how it would affect your low end torque, but i would only use it for those few times im sure zach might be able to relate here, where if you donwshift to one gear and it puts you at 6100 so the furthest you can downshift puts you at 4300 rpm or so and you have that couple seconds of lag before you go back into power, i believe opening the runners under load 5-600rpm sooner would eliminate that lag
Old 12-04-2007, 03:08 PM
Chiquae07's Avatar
Re: A Few New Pics
ive driven a spec before. i know exactly what you are talking about. hell, i might get rid of the auto se for one. and im highly debating it. but back on topic, would cams get rid of that 'lag' so to speak? i havent driven a cam'd spec so i cant answer that question. i know that the secoing thendaries are opened by a vacumn, so hm.
so you are saying when you are going on a 1/4 run or w/e, after you get them opened in 1st, you'd keep them open until you stopped basically? hmm...that actually doesnt sound like a bad idea.
Old 12-04-2007, 07:36 PM
Re: A Few New Pics
about those secondary butterflies...if your gonna do anything, take em out. all they are is to help off the line part throttle torque, yknow for normal people getting groceries and shit. remove all the stuff, cut the butterfly shaft thingy by each runner, and pull all the stuff out. then jb weld the holes and sand it smooth. ive done it before and its not hard. plus the less restriction in the intake tracts the better.
Old 12-04-2007, 09:01 PM
ProZach626's Avatar
Re: A Few New Pics
I do have the IMS + TBS + TB ported. I did that about 2 months ago. I just need to fix a leak, where I didn't take the old IM studs out and didn't put the new ones in.
I'm keeping the butterflies in. It's really not worth the loss in low end TQ, since mine is a daily driver, unless boosted.
