Old 11-25-2007, 06:23 PM
beatboxn420 beatboxn420 is offline
First System..
So.. I have two MA Audio HK12X2's. Im thinkin about for my amplifier.. MA Audio HK4000D. Its a mono amp. So, my question is, can I run 4000 watts to each of my HK12's off one HK4000D?
-Tj
Warning: Objects In Mirror No Longer Matter
Old 11-25-2007, 06:46 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: First System..
no.
i wouldnt run 4000w to that sub even if you wanted to, the RMS is 1500.. it probably wont even hold a clean 1500w rms let alone 4000
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-25-2007, 09:05 PM
Re: First System..
ive read up on the subs, other owners of the subwoofers said they have ran 4000 to each sub and had no problems..
-Tj
Old 11-25-2007, 09:48 PM
BikerPaintballdude BikerPaintballdude is offline
Re: First System..
I Tried looking these subs up and didnt find anything. But seeing that it is 2 12" your prob looking at around 1500 watts. So depending on there RMS (which if you could find that and post it that would be great) Id either go with one of these 2 Hiphonics amps: The 1606D Brutus amp or the 2006D Brutus amp (which may be too much power) But they put out less power then is listed but the 1606D= 1600 watts 2006D= 2000 watts.
Old 11-25-2007, 09:57 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Re: First System..
Yeah but are you sure the amp is really capable of 4000 watts? Still, my goodness, 4000 watts for each sub is a ridiculously huge amount of power. I assume your ride is built for this?
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 11-25-2007, 10:02 PM
Re: First System..
Here:
http://www.sonicelectronix.com/item_...io+HK12X2.html#
Scroll to the bottom and read all the customer reviews. One says he's pushin 4000 to each.
More Reviews with putting high amp to the subs
http://www.onlinecarstereo.com/CarAu...roductID=14705
-Tj
Old 11-25-2007, 11:04 PM
alphalanos alphalanos is offline
Re: First System..
just because one guy says he put 4kw to a sub doesn't mean you should. go with what the manufacturer recommends. they built the darn things.
96 EJ6. Future home of boosted B18C1.
Old 11-26-2007, 04:55 AM
pre98zetec's Avatar
Re: First System..
lol theres guys on online car audio say they hit 170db off of legacy subs too.. do you beleive them too?
MA subs will blow even if you put recommended RMS on them, i've seen it happen alot.
besides.. what kind of electrical do you have to support 8krms?
-Josh-
Old 11-26-2007, 08:44 AM
Re: First System..
...Like the title of this forum says... its my FIRST system... I know a little bit about systems. Ive read up on some of the basics, some of it sticks and some doesnt (as in I do not understand). So throwing the book out and starting from scratch.. What do YALL recomend? As in AMP, Wiring, Capacitors (if any), box square footage/design. I dont know very much, yall are pretty much "professionals" in my eyes, so Ill trust your opinion/input. But when it comes down to it, I just want a reliable, hard hitting, high dB rating system. Basically, just a badass system.
-Tj
Old 11-26-2007, 09:23 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: First System..
people that run 4000 watts to that sub are playing it for like 3 second burps, I'm sure it can handle that - it will not handle 4k watts all day, and neither will the electrical system.
Old 11-26-2007, 02:59 PM
pre98zetec's Avatar
Re: First System..
Whats your budget? hopefully not under 1k
-Josh-
Old 11-26-2007, 05:22 PM
Re: First System..
I say you put like around 2000-2500 watts and up to each sub like I said (actually i wasnt sure that I typed in that you need 2 of those amps but I ment to) But 4000 watts to one sub and you are going to have 2 of them! My gosh you would need to have the freaking Hoover Dam and like 30 batteries just to power it. And in your first post (I might have just read it wrong or you may already know this and I sound like a moron) But it said "can I run 4000 watts to each of my HK12's off one HK4000D?" You would have to have 2 of those amps to run 4000 watts to each sub, because if one amp is rated at 4000 and you spilt the power between 2 subs that = 2000 watts each. But I think you should get that amp if its any good and split it between the subs wired parallel that should be plenty of power, or you could just get 2 amps rated at 2000 watts. And I agree with pre98zetec I certainly hope your not expecting to do this with limited money cuz this is going to cost a bit.
Old 11-26-2007, 10:25 PM
Re: First System..
well, i can get the amplifer for 450. i already have have that money. and im planing on getting a larger alternator or 2 more batteries for about 150. as in for the wiring, i dont know how much ill need for that, or what type of wiring i need. and if i need capacitors, than ill get them too. im thinkin of spendin a grand for amp/alternator(or more battieries)/capactior/wiring. cause i already bought the 2 subs.
-Tj
Old 11-27-2007, 10:47 AM
Re: First System..
Yes you will definatly need an alternator because I am going to have to have one with just 2000 watts. Wiring wont cost you that much but have you put thought into what box your going to buy, or make. And if you get just one of those amps you would be fine and you could definatly get all that stuff for under one grand. But the alt will cost you a bit to get a good one unless you just add one on to the one that you already have and you will need another battery for sure. And do you know if you are going to make a custom box or get it done profesionaly?
Old 11-27-2007, 04:23 PM
Re: First System..
i dont know about the box. im not sure if it should be sealed or ported. or what type of deminsions i need. and i also dont know if i should get some capacitors, and what farads they whould be rated at. im thinking about buying all the supplies.. and the having the box built. and having it all professionally installed. cause right now im in the middle of a crossroad. A) it goes in my 95 mustang or B) it goes in teh 2002 volvo s60 i might be getting. and with the mustang, i got the aftermarket headunit. but with the s60, to put in a head unit, i need it custom done, because the center console is wierd... heres a picture.
-Tj
