Old 11-25-2007, 05:55 PM
dumbluck2 dumbluck2 is offline
need new motor
plz list links to here i can find one thanks
Old 11-25-2007, 06:39 PM
maxwedge maxwedge is offline
A990 racer
Re: need new motor
How about calling a local salvage yard, they all network country wide? Why would we have to do this for you?
Old 11-25-2007, 08:04 PM
Re: need new motor
just asking i was online 11/2 hr's couldnt realy find any rebuild kit's or motors
Old 11-25-2007, 08:57 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: need new motor
You can contact Ed Morad for complete engine assy;
[email protected]
Old 11-26-2007, 06:33 PM
dtownfb dtownfb is offline
Re: need new motor
you can always check Ebay.
Old 11-26-2007, 06:46 PM
Re: need new motor
oki have ben looking around some.an have a few qustions. an the way i figure it if im geting a new motor i want to go supercharged. ? any how just wondering if this motor would bolt in just the same as the stock one did?
if you have any in put that would be of any use plz feel free thanks.
http://cgi.ebay.com/ebaymotors/GM-3-...1412QQtcZphoto
Old 11-26-2007, 09:40 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: need new motor
It will bolt in yes, but you will also need the PCM from an L67 vehicle, and probably the rest of the wiring harness to go with it.
The transmission should bolt up, but probably wont last long at all. So you at a minimum would need axles and a differential and probably more from a donor vehicle.
It can be done, and has been done many times, but theres quite a bit more too it than just dropping in an engine and going. If youre really interested I can dig up more info, but Im just going off memory from discussions at another forum.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 11-27-2007, 05:31 PM
Re: need new motor
ok yea the motor in the link come"s with motor trans pcm an wireing.so all i would need from there is the pansnger side axle from a gtp rite?i was reading some where that i can reuse the stock wires with this adapter from think it's acc?
but yea im really interested in doing this i don't see it being that much harder then what i allready did to the car? an if i can use my stock wires with that kit it should be gravy! an i realy don"t need the car rite now so i have time to mess around a bit with it.a big worrie is spending the money on the used motor an it being a dud? or geting it an runing in to a hole bunch of crap cousting me way more then i ever thought. iwant to spend no more then $2300 if not ges ill tear back down the old motor an find out my it has only 25lb on #1 cly with 94k miles on it
Old 11-27-2007, 07:00 PM
Re: need new motor
ok guys just got off the phone with my friend that has a 98 g prix with 70k on it she only wants $650 so im going to look at it if it starts an runs good there we have it motor an trans $650 the trans will work in my car rite?
Old 12-01-2007, 06:18 AM
panzer dragoon panzer dragoon is offline
Re: need new motor
find out if that tranny is a 4T60 and not the usual Intrigue 4T65e
-I looked into it and believe you are ok.
