Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 11-25-2007, 01:33 PM
Garbagemann55 Garbagemann55 is offline
98 Avalon ABS Codes
How do you manually get ABS Flash Codes?
1996 White Isuzu Rodeo 5-SPD
Old 12-12-2007, 12:15 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 98 Avalon ABS Codes
Got a hunch you figured this out by now but, I'm pretty sure it takes a dedicated ABS scanner. If you know otherwise please let us know.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-18-2008, 03:53 PM
csaxon csaxon is offline
Connect jumper wire between DLC terminals Tc and E1. If a code is stored, 4 seconds will elapse and ABS light will begin to flash a 2-digit code.
First number of blinks will equal first digit in code. After a 1.5-second pause, second number of blinks will equal second digit in a code. If 2 or more codes are stored, a 2.5-second pause will separate codes. After a 4-second pause, all codes will be repeated .
It worked fine until I fixed it!
