Old 11-25-2007, 12:02 PM
biotix biotix is offline
water separator for air compressor
Hi, I was wondering if you guys can help me find a water and oil separator. And can you tell me if you can mount them horizontally and if not how would i go about mounting this to my air compressor http://cgi.ebay.com/Water-Separator-...QcmdZViewItem?
Oh and btw I have one of these http://www.sears.com/shc/s/p_10153_1...+%26+Inflators
IT is an oiled air compressor and I dont want oil messing up my paint job.
Old 11-25-2007, 12:29 PM
freakray freakray is offline
AF Modelrater
Re: water separator for air compressor
They're calling that an inline unit and looking at the connections it is, but the bleed on it for the moisture is on one end which is usually mounted downwards.
I would advise you contact the seller and ask them if you can mount it horizontally if that's what you're looking to do.
Do you have a pressure regulator? If you don't you may be better off getting a regulator/filter combo unit:
http://www.lowes.com/lowes/lkn?actio...0AV&lpage=none
Alternatively, if you only need the filter, go to Lowes and buy one of these, you'll still be saving money over the ebay one and will at least know what you're getting:
AF User Guidelines
Old 11-25-2007, 12:45 PM
my air compressor has a regulator.
Do you know if that filter will seperate oil too? Because I have a oiled aircompressor.
Old 11-25-2007, 12:55 PM
AF Modelrater
You honestly should not need an oil separator, there was a thread on this not too long ago, you may want to search for it. If you do get oil on the outfeed side, the water trap will be able to handle it. If you get a water trap with a clear bulb, you will be able to monitor it.
What pressure range will the regulator on the unit give you, if it's max is 125psi per Craftman's spec then it will likely not give you the control you need to airbrush (15 - 40 psi)
AF User Guidelines
Old 11-25-2007, 01:42 PM
Alright thanks for your help. I will got to lowes and get the item you posted.
Old 11-25-2007, 03:03 PM
klutz_100's Avatar
Old 11-25-2007, 08:56 PM
cyberkid's Avatar
cyberkid cyberkid is offline
Here's a thread that I started a while back:
http://www.automotiveforums.com/vbul...d.php?t=755472
In the end I got 3 filters...yes, I'm excessive... and yes, I'm extremely paranoid when it comes to painting.
A 2 in 1 setup which filters oil and water and a final filter/regulator setup...
HTH
Steve
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 11-25-2007, 09:58 PM
Can you show me a link to the 2 in 1?
Old 11-26-2007, 12:04 AM
cyberkid's Avatar
Sorry these are in Chinese....couldn't find any of the same models on other sites...
http://tw.f3.page.bid.yahoo.com/tw/a...8?u=pine009.tw
This is the 2 in 1 I'm using but mine doesn't have the regulator and guage, I bought from this seller too.. nice guy..
The 2 parts are exactly the same.. only difference is the filter core
http://tw.page.bid.yahoo.com/tw/auction/1153860707
same model as my last water filter/ regulator, bought at an air-compressor shop..
fyi the 2 in 1 set cost me 44.29US including 2 fast connectors and shipping.
The filter/regulator cost me 23.15US.
HTH,
Steve
