Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-25-2007, 10:58 AM
jeff983000gt's Avatar
jeff983000gt jeff983000gt is offline
spongy clutch peddle???
in my 2000 trans am ws6, sometimes the clutch peddle feels real spongy..like alot of give in it, and if i shift quickly throught the gears the peddle will like almost stick to the floor for a second before shooting back up..car only has 34000 miles on it..im thinking maybe bleed the system out, maybe air is in the lines??? any opinions?
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm summit throttle body
85mm bbk ssi intake
fast fuel rails
30lb ford racing injectors
spohn strut bar
msd ignition coils
msd 8.5mm spark plug wires
edelbrock shorty headers
upgrade cam/ port and polished heads
SMG dyno tuned ( 375 rear wheel hp )
magnaflow cat back
slp y pipe
umi bolt on subframe connectors
umi rear control arms
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 11-26-2007, 08:38 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: spongy clutch peddle???
sounds like a good place to start, cheap.
Old 11-26-2007, 03:39 PM
ya ill probly do that..anyone have experiance with that? where is the bleeder located? can you do it from the engine compartment, or gotta jack up the car?
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 11-27-2007, 12:21 PM
docholiday5150 docholiday5150 is offline
on my 94 ta i dont have a bleed valve i bleed by loosing line and gravity bleed then by pumping petel like 200 times its hell on your leg but thats what gm told me to do
Old 11-27-2007, 01:25 PM
ok and where is the slave cylinder located so i know where to look, and drain from...thanks
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
Old 11-27-2007, 02:46 PM
the slave cylinder is located on the drivers side of tranny where the motor and tranny hook together be sure to retighten line after gravity bleed before pumping petel if your unit has bleeder it will be on the slave cyl. hope it works
Old 12-08-2007, 10:16 PM
hey guys ive been meaning to write back..my clutch peddle still feels real loose at times...i had my car up in the air a few days ago looking from where to bleed the clutch line out of, and wasnt sure if i was in the right spot..is it the steel braided line on the driver side of the tranny? you pull it out and let it bleed? or what? i wasnt sure so i didnt attemp anything..
2000 trans am WS6
FTP 85mm intake
85mm jet maf
85mm bbk ssi intake
fast fuel rails
spohn strut bar
msd ignition coils
magnaflow cat back
slp y pipe
umi panhard bar
4:10 rear end gears
stage 2 spec clutch
