Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 11-25-2007, 09:28 AM
phipps phipps is offline
Removing Filler Hose - 96 Explorer
I have a 96 Ford Explorer that needs the fuel pump changed. I'm going to do it myself, but I can't figure out how the fuel filler hoses come off the tank. They do not have standard hose clamps. They are completely metal. Anyone have any idea how I remove these?
Old 11-25-2007, 10:30 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Removing Filler Hose - 96 Explorer
Don't know specifics on the '96, but often times it's easiest just to loosen the whole fuel tube and drop it with the tank. Many times there are 3 8mm bolts inside the fuel door that you can loosen and the entire tube will come out with the tank.
-Rod
Old 08-24-2011, 07:09 PM
bfar62's Avatar
bfar62 bfar62 is offline
the hose connections are similar to fuel line connectors, just bigger, I used large channel locks to compress mine enough to release the hoses
