Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 11-24-2007, 12:53 PM
kevnchelle kevnchelle is offline
Unhappy my 2000 zx2 s/r is knocking- help
Hi, I have a 2000 zx2 s /r 140,000 miles on it. It has been running great, but i was out shopping yesterday and needed gas. I went and filled up, when i started it afterwards, it was idleing weird, rpms were going up and down. I decided to go on my way and a few feet later it started knocking really bad. Then it stalled. I called the tow truck and when I arrived home tried to hear where the knocking was comming from, i believe it is from the bottom of the engine. It almost sounds as if you put a pop can in there. The car starts and idles it doesnt really knock when idleing but when you press the gas its horrible. Please give us some advise.....THANKS
Old 11-24-2007, 01:44 PM
inafogg inafogg is offline
Re: my 2000 zx2 s/r is knocking- help
hello the first thing to do is check for oil pressure
Old 11-30-2007, 09:15 AM
TeamExploder TeamExploder is offline
Send a message via AIM to TeamExploder
Yes, I would say the same thing check the oil pressure, just hope your bottom end bearings aren't going bad. Only had a zx2 up to 116k before i totalled the poor thing
1996 Explorer XLT 4X4 Auto. 4.0 OHV BWM to Fulltime and auto 4X4
1999 Malibu. 2.4L DOHC Auto
2000 Explorer XLT 4X4 Auto 4.0 SOHC
Old 11-30-2007, 12:10 PM
Thanks for your help i am going to buy an oil pressure tester this weekend. I will post back with the results.
Old 11-30-2007, 02:09 PM
What kind of oil filter do you have on it?
Old 12-26-2007, 10:40 AM
Its an stp oil filter, upon further inspection of the car, i found the timing belt was missing 19 teeth, i never got the oil pressure tested, but i am going to start with the timing belt today
Old 12-26-2007, 03:20 PM
Deffinette possibility of that. Just don't use FRAM oil filter.
Old 12-27-2007, 12:24 AM
Well my problem was solved. All the knocking was caused by being out of time. Replacing the timing belt was a bit difficult but definatly worth it! Thanks everyone for all of your help!
Old 02-01-2008, 03:29 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
please tell me your running 91 or higher oct....
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 04-03-2008, 09:35 AM
no should i be?
Old 04-03-2008, 09:44 AM
Originally Posted by kevnchelle
no should i be?
I always used regular gas in mine.
Old 04-03-2008, 09:52 AM
i used regular before the timing belt issue and afterwards thus far....the only difference is before i changed timing belt i got 38-40mpg now i get 30-35 mpg otherwise its running strong....with no knocking
Old 04-03-2008, 09:57 AM
Yeah you were getting good gas mileage because the motor wasn't running right, 30-35mpg is normal gas mileage for the ZX2, depending on how ya get on the throttle
Old 04-26-2008, 11:59 AM
the S/R pcm is ment to run 91+ octane. if your running 87 your going to detonate the car to death.
