Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 11-23-2007, 10:26 PM
mrmustang8 mrmustang8 is offline
1986 crown vic redline
How many rpms can an 86 crown handle, its got the 5.0. i am going to put performer rpm stuff on it. Will the engine handle 6500 rpms?
Old 11-24-2007, 01:21 PM
1996Chreokee 1996Chreokee is offline
Re: 1986 crown vic redline
with the right parts (cam, rods, etc) you could run it that hard but you will be out of your highest power curve. why do you want to turn it so hard?
Old 11-24-2007, 05:39 PM
Because the rpm range for the performer rpm ends at 6500, I am going to use a performer rpm manifold, cam, and a reguler performer carb, with longtubes and ported e7 heads. I was wondering if the oem vic shortblock can handle it.
Old 11-24-2007, 08:03 PM
i can't say for sure that it would hold up to that abuse but you power actually begins to drop off in the high rpms... your cam spec should tell you max range for power.... if the engine was balanced with upgraded rods it would be better for the higher rpm... even then though you get out of your curve for making the most power
Old 11-25-2007, 09:25 AM
reekor reekor is offline
Kids
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
