Go Back   Automotive Forums .com Car Chat > Nissan > Altima
Old 11-23-2007, 05:57 PM   #1
shab_xp
Ignition timing question
Hi,
I have a 1996 Nissan Altima with 2.4 L engine. Currently, I'm trying to adjust the ignition timing. I bought an inductive timing light. And knew that I should aim it at the crankshaft pulley between the alternator and the firewall.
The procedure seems very easy to follow. However, I realized that the distance between the timing mark on the pulley and the stationary timing pointer is very large. Consequently, you can get very different readings, if you read the timing from different angles.
Am I wrong?
Thank you.
shab_xp is offline   Reply With Quote
