Old 11-23-2007, 02:03 PM
silver02gt silver02gt is offline
IAC screw woes
So I've been trying to narrow down a sputtering/hard start problem with my 02 Grand Prix 3.8. I replaced the fuel filter, belt, and PCV valve, and still, I have problems with it.
When I turn the ignition over to start, I wait for the whine of the fuel pump, then I have to wait 5-6 seconds to get the car to start. I have to pump the gas, and once the car is started, I smell gas. I know this is also wearing on my starter.
I found this forum, and based on other threads, I started by unplugging the MAF sensor. The car started right up, no problems. Intermittent surges, but I assumed that that was the engine compensating for the lack of MAF info.
I decided to take off and clean the IAC valve with Chemtool. It came out clean as a whistle, but there's one problem. The first Torx T20 that I tried to take out broke off, leaving the majority of the bolt behind. It looked to be threadlocked into place (pinkish-red material on the threads of the other bolt) so I guess it's safe to assume that 1. the material used on the screw is hard but brittle, and 2. I need some sort of screw retrieval kit to get the damn thing out.
Help! Thanks.
Old 11-27-2007, 09:46 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: IAC screw woes
you might want to try posting this in the main grand prix forum, not the tips and maintenance section.
Why did you suspect the IAC? If when the maf is unplugged and your symptoms go away, the MAF is the problem.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 11-27-2007, 05:55 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: IAC screw woes
Thanks for the heads up Tim. This thread has been moved to the regular Grand Prix forum. Tips & Maintenance is intended for tips, FAQS and maintenance procedures. Future cooperation is appreciated.
Timeslip 08/12/06
AF Community Guidelines
Old 11-28-2007, 05:52 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: IAC screw woes
Welcome to AF
Are you saying that one of the IAC retaining bolts broke off and is still in the throttle body? If so, since they are so small, it's going to be difficult to drill to use an easy-out or screw extractor for removal. I'll assume since you read that the IAC is another known issue, you removed it as "maintenance" since it looked easy to do, and I don't blame you for that. It sucks when a supposedly simple job turns into a nightmare!!
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
