Old 11-23-2007, 12:39 PM
97 ZR 97 ZR is offline
Heat Problems
I have a 95 GA and the heat is only blowing out the vents in the dash. I replaced the mode switch and that did not fix the problem. Any ideas would be greatly appreciated.
Thanks
Old 11-23-2007, 02:40 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Heat Problems
Check the mode door and actuator. Also check for vacuum leaks that could render it inoperable.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 11-23-2007, 02:49 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Heat Problems
Sounds like the blend door is not functioning correctly.
Did you notice any thing disconnected when you serviced the modul ?
also this link might come in handy!
1999 Grand Am SS 3.4 OHV
Old 11-24-2007, 09:02 AM
Arokh Arokh is offline
Re: Heat Problems
This is a common problem.
Open the hood and follow the vacuum hose (probably hard plastic) coming out of the dash/firewall near the passenger side and look for breaks.
Hint - it's most likely broken up front, drivers side, near the battery. I think the layout of this hose has it rubbing on a piece of sheet metal near the battery mount and it eventually breaks it. You should find both pieces, snip a bit off each to get a clean end and patch it with a piece of vacuum hose.
Old 11-25-2007, 02:36 PM
Re: Heat Problems
Taking pictures of something else today, so I snapped a picture of where I fixed it in my car (95 GA). Yours might not be broken in the same spot but it's a place to start!
See link:
http://s39.photobucket.com/albums/e1...uum_patch2.jpg
