Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-23-2007, 12:26 PM
bleedEGLblue's Avatar
bleedEGLblue bleedEGLblue is offline
Water/Methanol Injection
I have been doing a little reading on the topic and cant seem to fully understand it. I know that this system is run to cool combustion chambers by mixxing the fluid in with the air mixture, and also increases the octane of the fuel. My question is, are these run with Intercoolers? Or is it obsolete with the FMIC. Anybody here run meth/water? Any pros cons?
Live From The Great State of Hockey
93 Eagle Talon Tsi
Rebuild TTD:
Ross Racing Pistons(.20 over) - comp 101200's - Head Rebuild Kit - Port/Polish - Big 16g ported Internal WG 34mm - DNP Tubular Exhaust Mani - Megan Racing O2/Outlet - Apexi DP - Walbro 255 - 660cc's - Venom FR - JDM FMIC - Link - Apex'i timer - Short Throw - OEM TB - -6 Fuel Line - FPR - Water/Meth Injection - GM MAF
Previous Mods: GReddy type-rs BOV, 2.5" exhaust, ED Drifter BodyKit, Python security
Old 11-23-2007, 12:34 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Water/Methanol Injection
You don't need an intercooler to run water/meth. But if you have a turbo you should have an intercooler anyway. I have been looking into this as well. It's not really an expensive mod either
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 11-23-2007, 01:11 PM
Lol well I know you need an intercooler with the turbo But I was just trying to figure out if my JDM FMIC or a meth/water system is more beneficial.
93 Eagle Talon Tsi
Rebuild TTD:
Old 11-23-2007, 02:08 PM
Testiklees
Use both
Tim
1990 Talon AWD
PTE SCM5031
Old 11-23-2007, 06:11 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
My buddy has it on his car and swears by it. I want it, but I think I'll eventually save it for my 1g project, (whenever that happens). He has a FMIC with meth injection. Only thing is, if you get your car tuned with it, don't let it run out of water/meth, when boosting high. You might end up running too lean then. But other than that I hear it's supposed to be great, be like having race gas all the time, a cooler intake charge, and cleans the carbon out of the combustion chamber.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 11-24-2007, 12:42 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
The water cools the air temp and the meth/alocohol raises the octain. Very cheap and effective mod. I have heard of people droping intake temps by 30-40 degrees. The only problem is that liquid isin't compressible so your compression ratio will increase slightly.
Some kits come with a controller that will lower boost or retard timing if there is a problem with the system so you dont blow your motor.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-24-2007, 01:13 AM
Very interesting. This sounds like a decent idea, but I do have my worries about the engine. Also, I wonder how long a tank would last you if was 7 or 8 quarts. And where in the hell would I put it lol.
93 Eagle Talon Tsi
Rebuild TTD:
Old 11-24-2007, 01:29 AM
Testiklees
Some use the windshield washer reservoir and some kits i think come with a bottle you would mount in the hatch area.
Tim
1990 Talon AWD
PTE SCM5031
Old 11-24-2007, 01:56 AM
Holset powered 420a
Mount it anywhere you would have room. It would last a good while I would think. It would only run at a set psi, so just run a manual boost controller and set it right below where you want it to turn on so it only runs when you are racing or something.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 11-24-2007, 09:58 AM
I think I am going to venture into this mod. Sounds like something fun to experiment with.
93 Eagle Talon Tsi
Rebuild TTD:
Old 11-24-2007, 11:10 AM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Alky injection is deffinatly worth it. On my setup if I was to run an injection kit I was told my Sean Glazer(owner of extrememotorsports) that I would see an easy gain of 100awhp. Its not too expensive but, some of the kits require a good amount of time to hook up.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 11-25-2007, 11:05 PM
Dan L. Dan L. is offline
Water Methanol injection has been around since WWII when it was used on fighter planes for power take off and combat. During combat the pilot would have about 20min of increased hp until the fluid carried ran out.
Water Methanol is different then Nitrous. With Nitrous you are adding oxygen to the engine combustion charge leading to more hp. Where as W/M you are adding an oxygenated fuel.
Another way to add more air is though forced induction, turbo or supercharger. Problem is that this forced air will heat up. Add to much air and the ratio of Air to Fuel (A/F) in the combustion chamber will be to lean. A lean mixture is prone to detonation or engine knock and leads to engine damage.
On a turbo or supercharged engine, the A/F is usually set to around 11.5 to 1. At 11.5 the automotive manufacturers are adding in between 10-15% extra gasoline just to cool the cylinder walls and prevent detonation. This extra gasoline is not burned until it goes out the tail pipe and thus you need a catalytic converter.
Now add in W/M. The mixture helps cool the intake air charge from the turbo or supercharger. It will also increase the octane rating of you base fuel by up to 25%. The higher the octane number the better the fuels resistance to detonation. Now you can safely remove that extra 10-15% of fuel and run the engine at an A/F of 12.0.
Why run at 12.0? Because an engine will make maximum hp at 12.0-12.5. 14.5 is best for emissions, and 11.5 is best for detonation control.
W/M injection gives you all the intake cooling and detonation control needed to run your engine at its maximum output potential.
for more information you can go to www.labontemotorsports.com
Best regards,
Dan
Old 11-25-2007, 11:10 PM
Wow, you are a wealth of info on the subject. Thanks a bunch. Helped out quite a bit seeing some numbers.
Welcome to AF. Hopefully you will be an asset, starting off with a boom like that.
93 Eagle Talon Tsi
Rebuild TTD:
Old 11-26-2007, 04:29 AM
kjewer1 kjewer1 is offline
AF - Advisor
100 hp is pushing it. I usually only pick up 50-70 going to 117 octane race fuel, for comparison. But it can be very worthwhile. When done properly, which is a vast topic of its own, I've seen it be very effective. As an example, a direct port injection setup running 75% meth to 25% water with an injection DC directly proportional to IDC (don't recall the value), did just as well as my 2g did on 117 octane. Both our cars were running 30 psi on 2.4 liters at 65 lbs/min, with the same AFR and timing. Only difference was the fuel. Quite impressive.
As Mix mentioned, you need to have a fail safe in place to prevent you from running meth settings on plain pump gas. Many prepackaged kits come with at least a warning light, but I prefer to implement some kind of hard stop, easily done with DSMlink or an EMS. With the AEM for example, you can use the nitrous maps to have it default to standard timing and fuel settings when the meth runs out or a component fails.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-26-2007, 10:16 AM
HP gains vary from vehicle, yes 100hp gain on a DSM would be high. With W/M you can get the same performance on pump gas as you would with C116 race gas for your tune.
Agreed that a Fail Safe is a good option. Since you lean out the A/F with W/M you don't want to get caught without W/M or your engine will detonate.
Zetronix makes a Fail Safe that monitors A/F ratio. Or a lower cost solution is the IFS-10 by Labonte MotorSports that monitors fluid flow. Most Fail Safes will output a 12V signal in the event of a fault. This can be used to retard timing with an aftermarket ignition box, activate a solenoid to limit turbo to wastegate pressure, or switch maps like in an AEM.
Best regards,
Dan
