Old 11-23-2007, 11:47 AM
dansouth dansouth is offline
PO128 code
has anyone had this code. does anyone no where the coolant temp sensor is located 2003 chevy trailblazer feedback will help. Thanks
Old 11-23-2007, 03:41 PM
maxwedge maxwedge is offline
A990 racer
Re: PO128 code
This refers to the engine running out of temp range, not the temp sensor necessarily, this is almost exclusively a bad thermostat. http://service.gm.com/gmspo/mode6/pd.../2003file2.pdf
Old 11-23-2007, 04:35 PM
Re: PO128 code
Thanks for the reply that what I thought it might be. thermo probally stuck open.
Old 01-07-2009, 06:12 PM
ewoody625 ewoody625 is offline
Re: PO128 code
Did changing your tstat fix the problem? I'm showing a PO128 on my S10 and I just want to know if its the tstat or the temp sensor
Old 01-07-2009, 08:01 PM
A990 racer
Re: PO128 code
Welcome to AF, usually not going to get an answer on a thread this old, but that code points to a T'stat. BTW you really are in the wrong forum also.
Old 01-18-2009, 01:00 AM
rubberman rubberman is offline
Re: PO128 code
its the thermostat. change it and you;ll be ok.
2000 Grand Prix GT w/ gold package.
K&N CAI intake, U bend delete, ZZP PCM, Ractive oval exhaust tips, ZZP 3" downpipe
2004 Chevy Trailblazer EXT
Keep on Keeping on...
