Old 12-05-2002, 09:00 AM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
1996 JDM H22 authenticity
Here is my situation. I just swapped a JDM H22A in my 1997 Accord. The engine has an internal coil and it came with a P13 ECU. I used a conversion harness for wiring. My person I got the engine from said that it is a 1996 H22. Was he correct? To my knowledge, 1996+ cars are OBDII. This so called 1996 that I have in my car came with a OBDI (P13) ECU. Is it different in Japan, is my engine really a 1995, or can you just slap a OBDI computer on a OBDII engine w/o problems?
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 12-06-2002, 01:45 AM
drift's Avatar
drift drift is offline
Send a message via AIM to drift
it's not a 96 motor.
the ecm plugs are different on 96+ OBDII Hondas
Old 12-09-2002, 11:03 AM
NIMO NIMO is offline
Just look at the head, take the heat shield off and you will see the year stamped on the head, go by that.
Old 12-20-2002, 04:33 PM
And for my next question
I am getting CELs for my O2 sensor and EGR lift sensor. The codes are 41 and 12 respectively. I checked both sensor and its my 2nd O2 sensor that isn't working. Since the OBDI Prelude only uses one )2 sensor, then my second one shouldn't be read. What's the deal with that?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 12-30-2002, 09:58 PM
srelick srelick is offline
Send a message via AIM to srelick Send a message via Yahoo to srelick
They're both correct !
OBD1 has different plugs than OBD2 yet that has been known to vary. P13 ECU's come in different OBD versions as well. You might have a civic/integra P13. It will work but if it wasn't the original ECU for your particular motor JDM/USDM/EDM, there are sometimes problems.
one must first finish in order to finish first.
Old 01-15-2003, 09:38 PM
kumyaras kumyaras is offline
I thought that the P13 only comes in the JDM 1993 H22
Old 01-16-2003, 08:37 AM
So what ECU do the 1992, 1994, 1995, and 1996 JDM Preludes have?
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 01-18-2003, 07:32 PM
Toys7505 Toys7505 is offline
I have a 94 JDM H22A and it came w/ a P13 ECU. I believe that ALL H22's (either OBD I or II) run on the P13 ECU.
Correct me if I'm wrong...................
Old 01-19-2003, 04:51 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Clicking below may help your argument!! This is as close to accurate as I could find, and any further questions I would encourage you to contact Hondata.
Hope this helps!!
http://www.hondata.com/vehicles.html
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 01-21-2003, 06:51 PM
H22A ECU's
First,
Reply for Tony,
P13 ECU (92-95) Prelude OBD-1
P14 ECU (96-01) Prelude OBD-2
This is the norm. There are exceptions.
Second,
Thread Continuation,
One other question, can you get the block serial number? I need that to find out what car your motor came out of. Preludes weren't the only car that had H22A's in them and Japan wasn't the only market for these cars as well.
Like I stated earlier, you might have a '96 H22A with a P13 ECU.
If the car isn't being used on a daily basis, take a photo of the block stampings and the motor itself and the ECU (markings must be clearly readable).
I have a 97 Prelude P14 ECU going out to get modifiied by Hondata tomorrow. A couple of my friends and myself all have P13's in our Preludes (92-96 F22/H23/H22A/H22B). Some of my prelude friends and customers have P14's in their Preludes (96+)
