Old 11-23-2007, 09:20 AM
70165 70165 is offline
Solinoid Clicks But Wont Start
97 Grand Voyager 3.3 . Just replaced the starter because of a no start ( solinoid single click). No improvement. Battery is strong . Any idea where to proceed to next? Thanks in advance.
Old 11-23-2007, 10:28 AM
Re: Solinoid Clicks But Wont Start
Just to add,old starter comfirmed bad,new starter confirmed good. Still wont start only one click.
Old 11-23-2007, 11:17 AM
webbee webbee is offline
It might be corrosion in the wires or in the terminals. Check the grounds and also remove a bit of insulation and see if there is blue-green/white powder corrosion under the cable. If it's there replace the wire/cable.
The rule is usually:
One click, solenoid needs work.
Rapid clicking, battery needs replacing.
Are you sure the replacement solenoid is good?
As always, good luck with your project!
Old 11-23-2007, 11:21 AM
Bear Bear is offline
Like already said, clean battery terminals and then put a volt meter (15 VDC) on the battery and take a reading, should see 12.0 VDC. Then, while keeping the volt meter on the battery have some one crank her over and see what the volt meter reads, you need to see 11.0 to 11.5 VDC or the battery is not holdning a charge.
Old 11-23-2007, 11:55 AM
never mind, bad starter, bad battery.
