Targa Top.....
The roof leaks on the drivers side when it rains. Is there an easy fix to get this to stop or am I just gonna have to suck it up and deal with it. I know alot of del sol roofs leak.
Re: Targa Top.....
Last year I took apart my roof and used an an all-weather silicone caulk( wish I could remember the exact kind -I just picked it up from Home Depot -get something that is rated for marine or outside) which I ran a new bead between the the rubber seals and the roof. It was important to clean the roof insides before you apply the new caulking sealant.
I think I got this tip from the team del sol site, so I can't take responsibility for coming up with the idea. Anyway, the new caulking fixed the roof and any leaks I had, and it wasn't that complicated to take the roof apart. just a screw driver( philips head) and a socket wrench ( I think 10 mm). Hope this helps. |
Re: Targa Top.....
you're local honda dealer also should have some silicone grease that you can put on those seals, sometimes that helps.
Re: Targa Top.....
Re: Targa Top.....
There wasn't a recall, but there was a redesign of the seals. You have to replace the seals on the left and right side of the top, along with the single piece seal that wraps the windshield. Honda did a redesign in '94 to fix the issue. The seals will run about $276 from Manchester.
http://www.manchestermotorsports.com/index.cfm Part numbers: 72320-SR2-043 front 85141-SR2-033 85191-SR2-033 |
