Old 11-23-2007, 01:50 AM
rockwood84 rockwood84 is offline
02 silverado
i slowed down for a turn and when i gave the truck gas it wouldn't go over about 12mph and service engine soon light came on error message said engine throttle level below threshold. what the **** happened ? i took the negative cable off and let the s.e.s. light reset and it hasn't done it anymore. what would cause it to act up?
Old 11-23-2007, 02:26 AM
gizzmoinc gizzmoinc is offline
Re: 02 silverado
I just had this happen to me. What I had to do was turn the key in the on position, look under the hood and find the gas pressure line on the 5.3 its on the left side. When you take the cap off and press the valve you should get a steady flow of gas. If it trips out you need a fuel pump. Mine started but I could go over ten miles per hour. When I tried to it the gas it backfired and then cut off. Let me know if this works
Old 11-23-2007, 03:19 AM
Re: 02 silverado
hey thanks for the info. it just did it that one time and now it runs like a new one. don't know what got into it.
Old 11-23-2007, 08:33 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 02 silverado
How is your tune up and mileage?
Best not to disconnect the battery for a reset on check engine light.
The next time the light comes on get the code and post back code no.
MT
Old 11-26-2007, 02:59 AM
Re: 02 silverado
will do
Old 01-04-2008, 08:14 PM
Re: 02 silverado
fuel pump finally quit $420.00 later runs like the wind. thanks
