Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-22-2007, 06:52 PM
Ravi2937's Avatar
Ravi2937 Ravi2937 is offline
What Are Cam Gears? and will they help my car
if i install cam gears on my stock 1.6 si motor will it help and what do they do ?
Old 11-22-2007, 08:14 PM
Schister66's Avatar
Schister66 Schister66 is offline
AF -Advisor
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: What Are Cam Gears? and will they help my car
They attach to the cam and allow you to advance/retard your timing...since you have a single cam, you cant really do anything with them. Also, without tuning, you're not going to get anything out of it.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Old 11-22-2007, 08:20 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
The cam gear is the gear attached to the camshaft. The camshaft is was opens and closes your exhaust & intake valves (there are more parts involved internally, but this is a basic explanation). The cam gear is connected to a belt, which connects to your crankshaft (among other things). The belt synchronizes the valve timing (opening & closing of the valves) with the appropriate strokes of the crank (intake stroke, compression stroke, power stroke, & exhaust stroke). Basically it makes the intake valves open up at the intake stroke, the exhaust valves open up at the exhaust stroke, etc. This is a VERY basic explanation of how it works. I would recommend checking out this link and looking at the animated image: http://en.wikipedia.org/wiki/Four-stroke_engine
Watch the valves open and close and it's relation to the turns of the crankshaft.
The adjustable cam gears allow you to adjust the valve timing (when the valves open), to make more power. But unless you understand how and why you should adjust the timing, based on specific parts you have and power you're making, you should NEVER touch the timing. There is no exact setting to set the cam gear(s) to, that will work with every engine (1 setting on a B16A is probably not right for another B16A). With a stock engine, Honda already set it to where it makes the most power as well as the best fuel efficiency. Adjustable cam gears are really only for when you have an aftermarket cam(s), or you're going forced induction. Most people buy them simply for looks, and never adjust them or adjust them incorrectly.
Old 11-23-2007, 11:27 AM
Schister66's Avatar
AF -Advisor
The OP is in Canada...
Si = D series
