Wheel size on a 99 Grand Am
Hello,
I own a 99 Grand Am with factory 225/50/16 tires and aluminum rims. I'm thinking of buying a set of winter tires and wheels I found online. The seller claims these wheels were in an intrepid but will fit a grand am also. The size of the winter wheels and tires are 225/60/16. Would anyone be able to confirm this to me? I'm not sure if the bolt pattern is the same. Thanks in advance. Weber |
Re: Wheel size on a 99 Grand Am
The wheels are almost identical but there is a difference in the bolt patten. The Grand Am has a 5-115 bolt pattern and the Intrigue has a 5-114 bolt pattern. They also both have a 40mm offset. Although one millimeter doesn't seem like much they will not fit properly and you will have problems with them. Save your money and look elsewhere.
According to http://www.discountedwheelwarehouse...._Reference.cfm
'93-on Intrepid 5x114.5 '99-on Grand Am 5x115
'04 Cavalier coupe M/T 2.2 Ecotec Supercharged 14 PSI boost, charge air cooler, 42# injectors Tuned with HP Tuners Poly engine/trans/control arm bushings Self built and self programmed progressive methanol injection system |
Thanks for the info
Weber |
