Go Back   Automotive Forums Car Chat > Hyundai > Sonata
Old 11-21-2007, 12:56 PM
Bear Bear is offline
Oil Leak Update
Looks like the oil leak on my '07 3.3 liter was coming past the filter cannister cap, I took the air filter assembly off as well as engine shroud to get at the cannister. I took filter and center post out and cleaned everything up, when I re-installed the cap it went about three turns and hit a sticking point I took cap off and checked for cross threading (nope) so I reinstalled the cap, it again went on smoothly for about three turns and then hit a sticking point, I put a little more hand/arm muscle to the cap and she moved past the sticking point and then easily screwed down until seated. I am hoping that is the issue. Film at 11:00.
Old 11-22-2007, 10:14 AM
Re: Oil Leak Update
OK here is the deal, the post (large end) SNAPS into the cap and the small end goes into the reservoir well. In my case, the post fell out as I removed the cap and not being smart enough to look and see if it did indeed snap in, I just set the post in place in the reservoir and turned the cap down until I met resistance. Well, that meant that the "O" ring on the cap was not seated and I had an oil leak, I removed the cap, and then looked and sure enough there was a place for the post to snap in, I snapped her in and then I was able to fully seat the cap, and VOILA, oil leak is no more. (bad on me). :-(
