Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 11-21-2007, 12:47 PM
thunderrabit thunderrabit is offline
new to nissan
i am thinking about getting a sentra spec v but i wanna know what they usually go for, is getting a turbo for it easy, and is there something better?
Old 11-21-2007, 07:01 PM
slideways...'s Avatar
slideways... slideways... is offline
Re: new to nissan
of course theres something better. theres always something better. first of all what are you looking for in a car (be specific), and why do you want the spec V? and why do you want to turbo it?
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 11-22-2007, 12:45 AM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Re: new to nissan
Treadstone has a bolt on kit for 3100. You can find a 02-06 spec anywhere from 6k-15k. 03 is the best year, IMO. Didn't have AS shitty of a transmission as the 02 did. Also a few other problems were fixed, and the cosmetics of the 02/03 body style are FAR greater than 04+. 06 was the most flawless year, mechanically speaking. These cars are very fun to drive and more unique than a lot of other compacts out there, but trust me when I say they have a SHIT TON of problems. To name a few:
Transmission Problems (mine replaced at 52k, needs replaced again @ 90k. This can sometimes be prevented with the right fluids)
Soft Motor Mounts (easy fix)
Butterfly Screws ingested into the engines (easy fix)
Pre-Catalytic converter failure causing blown engines (easy fix)
For more info on Spec V's:
http://myspecv.com/
http://b15sentra.net/
those 2 sites have all of the knowledge you would ever need about spec v's, and more. Good luck.
03 Molten Silve Spec V:Nismo SS;JWT BSR;Nismo CIA;Khumo Ecsta ASX Tires;Slotted Rotors;XS Header;Apexi WS2 Exhaust;Magnaflow Hi-Flow Cat;Nismo Coilovers;ESMMI;WRP IMS;WRP TBS;TB Port;WRP Grounding Kit
Old 12-04-2007, 02:07 PM
nismo_pilot nismo_pilot is offline
Send a message via AIM to nismo_pilot
Re: new to nissan
if you wanna turbo down the road id advise the se from 00-01 since it has the sr20, which likes the hairdrier more than the spec does, if all else fails you can swap in any sr20 variant with minimal trouble, where as the spec motor swap or turbo is very intensive in the creativity department
2005 Aztec Red Spec-V
Nismo header, ES MMI, AEM CAI, UR Pulley, TB Coolant bypass, TWM SS, Kumho Ecsta's, 2x JL Audio W0 subs
9.02@ 84.4mph in the 1/8th....... Driver > Car
Old 12-04-2007, 07:32 PM
Re: new to nissan
but...the compression is still up there so i wouldnt go above what the turbo kit recommends without lowering compression. at least on pump gas.
Old 12-04-2007, 11:31 PM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
Re: new to nissan
people are hitting 8-9psi on stock internals iirc with no problems at all.
have you seriously takin a sr20 and putting it into gxe/spec bay? that alone isnt worth the cash. it would be easier seriously to just buy a sr powered car. there have been a handful of people that will convert the spec to a sr20det, and that costs maybe 3500ish. and in the end, you would need the b15 sr engine mounts and things for it to work properly. a se is cheaper than a gxe's these days, as most dont know the difference between the two.
and an auto sr20 to convert it to manual is also a money pit as well. the only transmission that will bolt up would be from the infinity p11 or the b15 se trans that has the viscous diff. the trans alone will cost you from 900 and upwords. this transmission is the FWD sr20 sentra gold essentially. there is work being done to get the qr transmission to bolt up to the sr20, but there is a bunch of stuff needed to buy.. one alone would be the bell housing. there is a thread of its build-up here :
http://www.sr20forum.com/driveline-t...-your-car.html
it all depends on how much powa you want. the sr20 varient of the b15 will hit broken ring land at about 270whp or so on stock internals. the qr25 will need need new internals at about 240whp iirc. and with the sr, you wont have the same tq steer with the turbo.
hell, new rods, pistons, rings, along with a gti-r manifold and t28 from a s15 silvia will get ya about 300+whp. of course you have to do the supporting mods, but that gets listy.
turbo - get a sr20 motor.
all motor - go with the qr.
and i wouldnt try to match the qr all motor bolt on numbers with a sr20de. lets just say there are a handful of N/A sr20de's that are in the 200hp mark. and these are stroked out motors.
2008 Mazda 6 ATX 2.3 Liters of Slowness
For those 9 seconds it takes me to reach 60mph, will be the most fun ill have in this car.
Old 12-05-2007, 08:49 PM
Re: new to nissan
re-read and get back to me, i said how hard it would be to change motors on the spec, i know how much work goes into swapping motors in the spec, i DO own one......lol
Old 12-06-2007, 12:04 AM
Chiquae07's Avatar
Re: new to nissan
man.... now i see it. i need to just chill this weekend. hit the slopes and relax. wrote 5 papers yesterday alone. and i got another one to write now. well, i'll write it in the morning before class.
sleep is essential. caffine doesnt help at all . forums arent helping me right now, as they are my only break from school so far.
i give up.
Old 12-06-2007, 03:35 PM
Re: new to nissan
lol reading is your friend on the internets
