Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-21-2007, 11:06 AM
jcaver jcaver is offline
popping noise
i have a 2004 impala and 4 some reason when i turn the steering wheel to the the right when i back out the drive way i hear a pop or if i'm at the red light and hit the gas hard taking off going foward i hear it also please help
Old 11-21-2007, 12:17 PM
inafogg inafogg is offline
Re: popping noise
need info as to where the noise seems to be coming from.does it do it all the time on acc or backing out driveway.is it a loud noise any additional info would be helpful
Old 11-22-2007, 12:08 AM
Re: popping noise
the noise seem 2 b coming from the steering or something and it does it in the morning or when the car sits 4 a little while and it's loud in the car but i don't know how it sounds outside but it rained here 2 day and i have'nt heard it
Old 12-01-2007, 07:13 PM
madman8874 madman8874 is offline
Re: popping noise
Intermediat steering shaft. This is a common problem with these cars. I pulled it out and greased it added fittings put it back in and it is fine
Old 01-28-2008, 10:07 AM
Re: popping noise
could you tell me where it's located
Old 01-28-2008, 12:02 PM
j cAT j cAT is offline
Re: popping noise
because you are not familiar with the location of this part i believe that you will need a repair shop to perform this repair. if you jack vehicle off ground and where the steering linkages are located next to front wheels you will see rubber/plastic bellows looking devices around axles/rods if grease is coming out of these rubbers you will need what they call boots or if these parts are damaged replacements. these parts fail rapidly when grease is lost.... also after this repair is completed do not accellerate hard with wheels turned as this damages these CV joints
Old 01-31-2008, 03:16 PM
super charger
i have a 2004 impala ss i would like to know which size pulley can i use to give me more power with out killing the motor and what type of other upgrades will i have to do to make it perform properly
