Old 11-21-2007, 09:08 AM
construct30 construct30 is offline
97 Power Steering Problem
I put a Remaned power steering pump in my 97 Cavalier a few weeks ago. It worked fine. Last night it quit working. No noise, didn't freeze, just no power steering, but only when I was not on the gas. When I was starting out or driving it seemed OK, when I let off the gas to slow down, it got really stiff. When I installed it, I ran fresh fluild through it a few times to get all the junk out like the book says, then I raised the front end and bled it I put the little flow control valve back in the hose. It worked great for three or four weeks and now bad.
I assume it is just a bad remanned pump, but am I missing some thing? The fluid is OK and looks clean and fresh. Why does it work at higher speed, but not at idle?
Thanks mark
Old 11-21-2007, 08:08 PM
shakewell shakewell is offline
Re: 97 Power Steering Problem
I'd be suspicious of the pump also.
Old 11-21-2007, 11:11 PM
I changed the pump tonight, again. I flushed it a lot more this time and went through the bleeding procedure in the service manual a few times. I'm trying to get all the bubbles out. I left the front up in the air for the night and tomorrow I will bleed it some more. I will see how it goes tomorrow.
Mark
Old 11-22-2007, 01:25 AM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
i guessing a bad pump also, i changed mine and didnt do anything special, i didnt even "flush" it, i just emptied the resivoir and refilled it once the new pump was in place,
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-25-2007, 01:45 PM
We've been driving the thing around the last few days and it seems fine. I hope it doesn't go bad again any time soon, or I will be suspicious. I wish I could have bought a new pump without going to the dealer. The remanned was cheap, but I always wonder about that stuff. I've had troubles in the past with remanned master cylinders too. I buy new if I can. I guess this just makes me wonder about remanned even more.
mark
